Ford 7700 Simms pump |
NomoreJohnDeere
Joined: 24 Jul 2017 Location: Missouri Ozarks Points: 308 |
Topic: Ford 7700 Simms pumpPosted: 06 Aug 2020 at 1:33pm |
I traded for a 7700
I'm giving it a going over and fixing things Looks as if the injector pump may have been off at some point. Whether it was rebuilt or not I have no clue. I noticed there are a couple set "screws" that have safety wire holes but no wire. I'm wondering what is going on there. Are they adjusted the way they should be and just not wired, or did somebody jack around with them. Does anybody know what those screws adjust? What part of the pump is that and what does it control? thanks |
HD3
NomoreJohnDeere
Posted: 06 Aug 2020 at 1:35pm |
HD3
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5205 |
Thanks(1)
Posted: 06 Aug 2020 at 3:55pm |
those are hi and low idle speeds. Why are you even worried about them? Remember those pumps have their own oil sump.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5279 |
Thanks(1)
Posted: 06 Aug 2020 at 7:30pm |
the full load fuel setting is under that cap on the top of the pump in front of the fuel delivery connections.
Tim NH
Joined: 16 Oct 2012 Location: Lancaster NH Points: 1155 |
Posted: 06 Aug 2020 at 7:56pm |
Might be good to change oil in pump. Are you familiar with doing that.
Tim
NomoreJohnDeere
Posted: 06 Aug 2020 at 11:33pm |
Yes I changed the oil but thanks for the heads up as some don't know about that.
The top bolt is not touching. I was wondering if that was normal? Should I screw it down so it does? I haven't watched it with the engine running to know if it moves, it does not by hand. thanks for responding |
HD3
PaulB
Posted: 07 Aug 2020 at 6:33am |
Move the throttle to full high speed and the top bolt will touch and the bottom one will not be touching. Those are the speed adjustments. as I mentioned the fuel setting is under the wire sealed cap, so the pump setting are most likely correct.
NomoreJohnDeere
Posted: 07 Aug 2020 at 8:35am |
ok
that makes sense thanks |
HD3
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8987 |
Posted: 07 Aug 2020 at 12:21pm |
don't understand why Ford did that. My 545B loader with 301/simms has oil feed from block
