WC compression test. |
Post Reply ![]() |
Beinepw#69 ![]() Bronze Level ![]() ![]() Joined: 04 Aug 2020 Location: Wisconsin Points: 16 |
![]() ![]() ![]() ![]() ![]() Posted: 06 Aug 2020 at 9:00am |
How do I do an engine compression test on a WC that has only a hand crank an no electrical system?
Acdiesel ![]() Orange Level ![]() ![]() Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2576 |
make sure you have a compression tester that threads into the spark plug hole.
if you pull all four plugs, have the throttle wide open and give it a few good hard pulls with the hand crank that is one way. Or you could pull one plug at a time and just start the engine and check them all that way. Dan
Edited by Acdiesel - 06 Aug 2020 at 9:12pm |
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF D15 SER.2 DIESEL D12 SER.I, D10 Ser.II 2-720'S D21 Ser. II Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
Rusty Allis ![]() Bronze Level Access ![]() Joined: 16 Jul 2020 Location: Rhode Island Points: 160 |
I think I would drag it around the yard in 2nd or 3rd gear with the compression tester screwed into it
Boss Man ![]() Orange Level ![]() Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 617 |
could belt it to another tractor
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21753 |
All spark plugs removed. Throttle wide open. Pull it in 4th gear so the tester pumps at least 10 times. Switch to the next cylinder.
TramwayGuy ![]() Orange Level Access ![]() Joined: 19 Jan 2010 Location: Northern NY Points: 11718 |
Most compression testers have a check valve to hold the highest pressure achieved.
Post Reply ![]() |
