190 xt no reverse
Josh(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Topic: 190 xt no reverse
    Posted: 26 Jul 2020 at 12:02pm
Was moving bales on the 3 point last night an out of the blue, no reverse. All forward gears seem fine and no odd noises. Right in the thick of haying season, so i don't know when i will get to look at it. Just looking for thoughts, simple or major repair. Thanks
Allis Express
'65 190XT, 37 B, '72 170, '83 8030, and the IH 560 was a mistake
Dave H (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 12:55pm
you my have a broken shift fork. have seen it happen.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 2:03pm
You have a broken shift fork. Take the top off remove fork and have it grazed I did mine last winter. Hardest part was getting floor panels off mine had nuts on the bottom the nut plates were broken on three hardest to get to.had my teenage son hold the wrench up by the transmission the easy to get to bolts still had nut plates. Don't lose the ball when you take the shifter shaft out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 5:39pm
Special dowel bolts on the shift cover go in the front left and right rear corners. Remove and install shift cover with tranny shifted into SECOND (3-4) gear..
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 10:54pm
Brazed fork on AD40 grader with good results
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 11:12pm
When you are pulling the shift shafts out push a socket that just fits in as you push the shaft out it'll hold the ball and spring compressed when you push the shaft back in it pushes the socket back out. After you loose the ball they are 3/8" diameter. I had to get a bag of them none could be found localy. I have 24 extras in my stash.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2020 at 7:30pm
Thanks for the information. By this weekend I'll get a chance to look and see if that is really the trouble. I will update you. Thanks again.
Allis Express
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2020 at 7:03am
Most of the time I welded the reverse fork without removing it from the shift cover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2020 at 9:46pm
It is a broken shift fork. I got a replacement from local salvage yard. Turns out to be wrong. I have a early model tractor with a late model transmission according to casting numbers on the shift fork i broke.
Allis Express
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2020 at 6:15am
ALL 190XT's were to have the transmission updated by your local dealership. No 190's, just XT's.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2020 at 6:22am
I don't think XT gassers were updated either...... emphasis on I don't think Wink
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2020 at 6:39am
They weren't as high of a priority as the turbo diesel. Do the turbo diesels first and then the gassers. Some dealerships may have had a dozen to do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2020 at 7:45am
Mine is an XT gasser.
Allis Express
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2020 at 10:18pm
Dr Allis, what is the preferred method for welding a shift fork?
Allis Express
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2020 at 7:00am
I prefer to replace instead of weld, but if a new fork wasn't on hand, it got welded. They usually break in the flat smooth area just above the fingers and it is easily welded with a rod made for cast iron/cast steel welding.. That's a somewhat special rod and all I ever used. Pre-heating the area a bit with a torch is a good idea.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2020 at 9:32am
Local blacksmith that did mine brazen welds shifter forks hes done hundereds for many obsolete machines never had one returned. Mine had been previously welded poorly when I took it apart.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2020 at 10:01am
My 180 broke a shift fork, took me better part of two hours to fish out the chunks as found the Second one broken when pulled.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2020 at 9:19pm
V it out and use bronze.             MACK
