D14 torque tube overhaul bearing & seal kit? |
Post Reply ![]() |
Page 12> |
nx08634 ![]() Bronze Level ![]() Joined: 14 Jun 2020 Location: Iowa Points: 25 |
![]() ![]() ![]() ![]() ![]() Posted: 07 Jul 2020 at 11:06pm |
So I'm replacing bearings in the torque tube. I lost a bearing on the shaft above the PTO (intermediate shaft)? My question is there a kit that contains all the bearings and seals for this job? I don't want to have to pull this apart again ever. So I figured I'd replace all the bearings. Or is it cheaper to take the time and shop for everything individually?
Any advice for reassembly welcomed. I just got the last of the shafts removed today and plan on getting it all washed out before putting it back together. Thanks for the help! Tim
I'd upload some pictures but I don't see that I can.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21925 |
Never was a "kit". One piece at a time.
Lynn Marshall ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2389 |
If you have the bearing numbers,you may be able to save a little by shopping around. That's your choice. A service manual would be helpful to set the shaft bearings. You may need a variety of new snap rings.
MACK ![]() Orange Level ![]() Joined: 17 Nov 2009 Points: 7664 |
Refill with universal hydraulic oil. MACK
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7506 |
You can see all the things you need and their part numbers on the AGCO parts book website. I am on that site all the time!
BTW it's a 58 D14
Thanks for the input everyone.
Do they offer a snap ring kit?
I was careful to keep track of which snap ring was where.
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24704 |
If there's even a hint of oil coming out of the brake rod slot area, you should replace the diff/axle oil seals. sorry, more sluggin of heavy cast... The original seal is 1/2" wide and no longer available. the replacement is 1/4" thick so two nicely go in. National oil seal # is 471765.
I probably will! Now is the time.
hmm, is there ANY oil coming out of the PTO lever ? THAT can be replaced while the tractor's 'split'. 50 cent o-ring..... Always wondered if an oilseal could be added as a 'deflector' and additional seal but for me to find out, I'd have to split my#1 ride here. That 'grrrrr' seal has always 'irked' me... every time, everyday I see it.... sigh Jay
No snap ring kits available today,as far as i know. The original snap rings may not be correct with new bearings, that's why they have a variety of different sizes available.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8640 |
I think when I had my 220 apart some thicknesses of snap rings were not available...be forwarned
[QUOTE=jaybmiller]
hmm, is there ANY oil coming out of the PTO lever ? No oil leaking there, but am going to replace a the rubber orings. |
Thanks for the heads up. I have access to a surface grinder so I can always make a thick one thinner.
So I was trolling the net looking for AC part #s. I looked at the AGCO site without any luck. I have bearing #s off the ones I removed, but the seal #s aren't giving me any results. I have a I T manual coming but not sure it will have part #s. The Jensons manual I have is ok but not everything that I was looking for. I will inherit this tractor at some point so I'm not wanting to just cobble it up.
I figured out the pictures!
Jim.ME ![]() Orange Level ![]() Joined: 19 Nov 2016 Location: Maine Points: 962 |
Please explain what you mean by looking at the AGCO site with no luck, maybe someone can help you. The D14 parts list with numbers is there. If you were looking for something specific and didn't see it, knowing what the issue was might get help on solving it. The AGCO site is not one where you purchase parts on line, if that is what you were looking for. You can get the part numbers there to do online searches with and you can talk to a dealer/parts suppliers, using the part number and correct name, when looking for parts. I have found the AGCO website works better with Google or Firefox, than IE, Bing, or Edge. The I&T shop manual is not a parts manual, it might have an odd part number or two, but not all part numbers. To me the I&T manuals supplement OEM manuals based on the couple different ones I have. As far as I know a Jensales manual is either a copy of the OEM manual or an I&T manual. I believe the D14 one is a copy of the OEM manual. Just my thoughts. |
I was looking for part numbers for the bearings/seals in the torque tube
Alvin M ![]() Orange Level ![]() Joined: 24 Jun 2018 Location: PA Points: 802 |
Agco Parts Books .com D14 Than Go To Page 148 All The Part # Are There
you might ( should...) put some wooden wedges at the tierod ends/axle. it'll keep the wheel straight and FIXED. I found out the hard way they can move real FAST when the back of the engine goes a bit wonky. from 'itll be OK support'.
Jay,
Look close a the top of the axle. It appears to have a block or wedge between it and the casting to prevent tipping. As I mentioned before the browser you use may make a difference. I found the site works best with Google. Using Bing or some other browsers, I didn’t always get the drawings, it wouldn’t return to the index, etc. You need to look for clutch, power director, transmission, differential or PTO parts. If you were looking for torque tube bearings and seals, they are not listed that way. 1. On the homepage click on: ” View Books”. 2. Enter D14 in the model search box. The Book title (D14 TRACTOR; AUXILIARY MOTOR - D14) and publication number(79001548) should appear 3. Click on the publication number. 4. Clutch and driveline parts start on page 144 and go through page 174. I see shafts and gears on page 168. Edited by Jim.ME - 10 Jul 2020 at 6:44am |
Yeah I saw them slippery 2by6's but unless tapconned into the concrete(hard to tell with my eyes..), they can move mighty dang fast.....I KNOW a 4by4 'wedge' did !! safety first....we only have 10 fingers and toes....
I'll give that a try. Thank you!
OK I've got a list of part numbers now. Where do you guys recommend as the place to shop?
So doing some searching for bearing co.'s and found
![]() Thanks for all the leads & help!
BTW I went with Timken & Federal bearings.
When you get the throwout bearing, buy the 'pilot' bearing as well,saves a lot of cussin 'I shouldhave...I shouldhave......' Also make sure the clutch fork is on the 'tranny' side of the cast iron 'tab' NOT the engine side... somehow mine was 'engine' side and you have to resplit the tractor to correct that 'booboo'. |
Will look at that, I put a new clutch in in 04.
Post Reply ![]() |
Page 12> |
