D17 hydraulics
Rick1263 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick1263 Quote  Post ReplyReply Direct Link To This Post Topic: D17 hydraulics
    Posted: 25 Jun 2020 at 5:52pm
I only have one hydraulic port on the back of my d17 looking to make hay using a haybine and square baler I need two hydraulic hookups for each of those units I only have one how will this work?
Edited by Rick1263 - 25 Jun 2020 at 5:53pm
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2020 at 6:21pm
If they are single acting cylinders, use a selector valve to switch between the cylinders.
Adding a double valve is also an option. The operators manual shows each setup.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2020 at 8:48pm
Early D17s (prior to Series 4) only have a high pressure/low volume single acting hydraulic system.  Not great for what you are wanting to use it for.
