Allis Chalmers B Woods Mower Pully |
rhaley
Topic: Allis Chalmers B Woods Mower PullyPosted: 22 Jun 2020 at 11:55am |
I bought a1940 Allis Chalmers B with a Woods Mower, but the pully for the tractor to power the mower is missing - anyone know what the part # is and where to get it?
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18967 |
Posted: 22 Jun 2020 at 2:00pm |
Scott B
Joined: 14 Sep 2013 Location: Kansas City Points: 1055 |
Posted: 22 Jun 2020 at 2:01pm |
I've seen theme with two different pulleys. One set up mounts on right hand side to the side PTO shaft. The other set up has a larger pully that connects to the rear PTO shaft. Might want to specify which you're looking for and put a a WTB note in classifieds.
D17 Series 1
Allis B- 1939 Allis B- 1945 |
Scott B
Posted: 22 Jun 2020 at 2:02pm |
Sorry, the first setup is a mount on left side of tractor (not the right side) |
D17 Series 1
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90812 |
Posted: 22 Jun 2020 at 2:16pm |
steve(ill)
Posted: 22 Jun 2020 at 2:17pm |
the pulley on the "LEFT" would use a taper shaft with a key... the rear PTO pulley would fit over the 6 spline shaft ( 1- 1/8 or 1- 3/8 inch)
Brian F(IL)
Joined: 14 Sep 2009 Location: Paxton, IL Points: 2733 |
Posted: 22 Jun 2020 at 2:34pm |
For Woods mowers, B's, C's, and CA's used the left side pulley. This was originally designed for the flat belt pulley.
WD & WD-45 (and maybe other models) used the pulley mounted on the PTO shaft. HTH
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 22 Jun 2020 at 2:51pm |
The D10/12 mowers used the PTO shaft mounted pulley. Any WOODS dealer can get a new pulley for you. Often a used pulley is cracked.
den/southern illinoi
Joined: 11 Sep 2009 Location: Sparta, Illinoi Points: 2092 |
Posted: 22 Jun 2020 at 3:00pm |
Sent you a PM. Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor. |
