AC5040 Gear Oil Leak
scratch67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scratch67 Quote  Post ReplyReply Direct Link To This Post Topic: AC5040 Gear Oil Leak
    Posted: 20 Jun 2020 at 3:21am
Small hole, legs of cotter pin sticking through. Located under the seat, bottom of transfer case.
What’s the purpose/function of this? Why do you think it would be leaking? Whats the fix process?
Thanks for you input.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2020 at 4:46am
Likely a bad seal somewhere in the dry compartment.  The cotter pin is there to keep a drain clear of bug nests or dirt, you commonly see them in clutch compartments, to let you know when the rear crank seal is bad, on a motor. HTHWink
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2020 at 9:46am
I believe it’s an axle seal leaking. Mine has been leaking for a while on the left side. I ordered the seal but I haven’t tackled the job yet. In the middle of hay season so I am tipping the hydraulic fluid off and making sure I don’t run it low.
This page was generated in 0.048 seconds.
