|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| Allis 8010 with PD 5 speed |
| Post Reply   |
| TimZ(TX)   Silver Level Access   Joined: 12 Sep 2009 Location: Schulenburg, TX Points: 258 |  Post Options  Thanks(0)  Quote  Reply  Topic: Allis 8010 with PD 5 speed Posted: 15 Jun 2020 at 10:35am |
   Found a 8010 2wd with PD. 4500 hours.  Has 5 gears, so they're calling it 20 speed.  They are referring to it as a partial power shift.  I know it has the high /low and has a left hand toggle switch for another range?  Would this be comparable to a powershift?  It looks to have a lot speed choices.  As I stated in my other post I do hay and have never owned a power shift tractor but most people say the PS is the way to go. Tim | |
     2-B's,CA,D15,D17,160,2-185's 8010
| Tbone95   Orange Level Access     Joined: 31 Aug 2012 Location: Michigan Points: 12246 |  Post Options  Thanks(0)  Quote  Reply  Posted: 15 Jun 2020 at 10:52am |
   It's not really like a powershift.  The hi/lo within 1 gear selection is the only thing that can be shifted on the fly.
| DrAllis   Orange Level Access   Joined: 12 Sep 2009 Points: 22140 |  Post Options  Thanks(0)  Quote  Reply  Posted: 15 Jun 2020 at 10:57am |
Imagine a 185 with 10 speeds on the gearshift and no neutral on the Power Director clutch handle.
| victoryallis   Orange Level   Joined: 15 Apr 2010 Location: Ludington mi Points: 2878 |  Post Options  Thanks(0)  Quote  Reply  Posted: 15 Jun 2020 at 11:42am |
   It’s honestly a step backwards from a D17.  Edited by victoryallis - 15 Jun 2020 at 11:43am | |
| HudCo   Orange Level     Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3948 |  Post Options  Thanks(0)  Quote  Reply  Posted: 15 Jun 2020 at 12:12pm |
   i have a real dumb question , if it has a five speed main and a hi -lo that equals 10 where is the other 10 speeds
| DrAllis   Orange Level Access   Joined: 12 Sep 2009 Points: 22140 |  Post Options  Thanks(0)  Quote  Reply  Posted: 15 Jun 2020 at 12:17pm |
7000 and 8000 series have a 5-speed main transmission, a 2-speed HI-Low range transmission, which makes 10 speeds. Then you combine that with a HI-Low power director clutch that makes 20-speeds.  Mr. Victory is still farming with a D-17 I guess...…….
| allisbred   Orange Level Access   Joined: 28 Mar 2015 Location: Hanover Pa Points: 1011 |  Post Options  Thanks(0)  Quote  Reply  Posted: 15 Jun 2020 at 1:18pm |
   How many gears/speed ranges do you have between 3.5-7mph without having to stop? Edited by allisbred - 15 Jun 2020 at 1:21pm | |
| Lonn   Orange Level     Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |  Post Options  Thanks(0)  Quote  Reply  Posted: 15 Jun 2020 at 1:24pm |
   For today's farming I'd take one 7050 PD before ten D17's but that's just me. | |
     -- --- .... .- -- -- .- -.. / .-- .- ... / .- / -- ..- .-. -.. . .-. .. -. --. / -.-. .... .. .-.. -.. / .-. .- .--. .. ... -  Wink I am a Russian Bot | |
| victoryallis   Orange Level   Joined: 15 Apr 2010 Location: Ludington mi Points: 2878 |  Post Options  Thanks(0)  Quote  Reply  Posted: 15 Jun 2020 at 7:24pm |
 If it was the 80’s and I was buying a new 8000 series the discount for a PD would have to be significant before it would be tempting. I sent my 7080 down the road because I hated shifting it. | |
| tomNE   Orange Level     Joined: 13 Sep 2009 Location: dorchester, ne Points: 1225 |  Post Options  Thanks(0)  Quote  Reply  Posted: 15 Jun 2020 at 7:43pm |
   2 gears between 3.5-7mph.   i'm up to date on the 7000 series but not 8000 but someone will have that knowledge.   I loved my PD.  the theory behind the AC PS is bullit proof but the speed selection sorta sucks.   I owned a 7020 PS and loved it on the loader.  field work, not as much but then i never baled with one.  I baled with a 7000 red belly and loved that tranny!   In fact they had alot of great ideas on a 7000 series red belly but had some   ty ideas also! | |
     AC from the start of my families farming career till the end! | |
| Leon B MO   Orange Level   Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2197 |  Post Options  Thanks(0)  Quote  Reply  Posted: 15 Jun 2020 at 8:48pm |
   We have 2 8050 ps and an 8010 ps. It has 6 forward and 1 reverse in 2 ranges. You can start in either range in 1st though 4th. After your moving you can shift up or down through all six gears, 1st up to 6, 6 down to 1st or up and down as needed without touching the clutch pedal. If you want to shift to reverse, you must come to a stop to shift, but it will not grind, it's all hydraulic. You have limited gears in the work range, yes. I plant corn with an 8050 2wd, I run in high range, 2nd gear and shift down to 1st for ditches and ends. I plant beans with the fwa 8050. This I run in low range, 5th gear and keep the the rpm's up for the hydraulics. But I can shift down to a crawl for going up hills or through draws. The pd trans does give you a better gear speed selection but once you pick a gear you can only shift either up or down one gear without stopping, clutching and shifting. If you're using a 185 now, going to an 8010 would be like going from a Ford Maverick to a Mustang. An 8010 with ps trans even better. Hope this helps. Good luck ,Leon B Mo | |
| wekracer   Orange Level     Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1590 |  Post Options  Thanks(0)  Quote  Reply  Posted: 15 Jun 2020 at 9:21pm |
   We have an 8070 FWA ps 8050 ps and 8010 ps. We have hills hollers and ditches. It’s nice to be able to go from 1.5 -7 mph without clutching. The 8070 does all the tillage. 8050 pulls a 13’ discbine and I plant,spread fertilizer and brush hog with the 8010.  I love the power shift. I have driven PD tractors and they would be fine if you have long straight flat roads and fields. But here I want a power shift.
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
