torque limiter, most likely....?
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: torque limiter, most likely....?
    Posted: 13 Jun 2020 at 6:51am
My son is trying to get the last of seeding done in my absence, due to my taking a job, and is way behind. He's pulling a 28 foot concord air seeder with the 8550. Yesterday he called me up and said that the tractor quit moving, just as if you stepped on the clutch. Told him to just stop until I get home. Went over to the field to check it out with him after I got home last night. Started it up, it moved probably about 50 feet, then came to a stop. Tried a lower gear and it went a little farther. Had Wyatt watching the shafts through the hinge. He said that both shafts quit turning when it stopped. Just about has to be the torque limiter, not.....? Thanks, Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2020 at 6:57am
Does the STEERING work???  Working steering means a good torque limiter  !!  Does the 1800 RPM red lite on the instrument panel work??  If the red lite is "on" and the steering works, your transmission pump has failed.  They are known for having drop box failures. I think splines on a shaft ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2020 at 7:11am
Also, try the range trans in LOW and HIGH.
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2020 at 7:58am
Tried high and low range both. Did it in both ranges. When it stops, no steering, 1800 rpm light comes on. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2020 at 8:39am
rut roh! i know where the money is gonna go now that Dad is making! whew!
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2020 at 2:38pm
Wink What are you saying,Cry no AC parts an ........................he will have to use a Confused green one.LOL
Hope you find parts easy Darrel, I never had anything but old stuff ether.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2020 at 6:43pm
Sounds like the transmission is very low on oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2020 at 9:41pm
Transmission oil level is good. We unhooked it from the concord today. Tried moving it away under its own power. Goes a few feet, and BOTH shafts quit turning when it stops. Step on the clutch and take it out of gear, and the top shafts over a few seconds, goes back up to speed. I pulled him to the edge of the field, and he had steering the whole way....top shaft was turning. darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2020 at 8:44am
The torque limiter on one of those (which I've never worked on) is a double disc set-up. So, there must be something hooking up some of the time allowing that top driveshaft to turn and then everything works....for a little while. A big job to pull the engine on one of those big tractors for sure.
