Governor Help for B with Zenith Carb
George Davenport View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote George Davenport Quote  Post ReplyReply Direct Link To This Post Topic: Governor Help for B with Zenith Carb
    Posted: 25 May 2020 at 7:53pm
I need guidance for adjusting crossover link with throttle control lever.  When I am mowing and I come to a tougher area the governor comes into play the engine  almost  cuts off.  I run about half throttle and the choke is about half closed for best results.  Does governor crossover link  hole receive the throttle post with a slight opening on the front of the junction or the rear of the junction adjustment?  I'm not sure if this is my only problem.  Any advise or pictures will be helpful.  The surge spring is connected.
Life is what happens while you are making plans for the future
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2020 at 8:37pm
#1 Do yourself a favor and get a service manual. That will explain in detail (often with pictures) anything you need to fix.
 #2 if you are running with the choke half close under normal operating conditions, you have carburetor problems.
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2020 at 8:50pm
Shouldn't have to have the choke pulled. Either dirt in the carb or main jet isn't adjusted right. Get it to run without the choke then go from there.
