6080 rear pto seal.
jrjuday View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jrjuday Quote  Post ReplyReply Direct Link To This Post Topic: 6080 rear pto seal.
    Posted: 16 May 2020 at 2:02pm
Hi, everybody. I have a 6080 that is leaking around the pto shaft. Is it possible to replace the seal without removing the entire pto housing? My service manual does not cover replacing just the seal, only removal and reinstall of the entire housing.
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2020 at 11:08pm
Yes you have to pull off that rear housing.  Pretty heavy so use a cherry picker.  The long PTO shaft that goes over the top of the ring and pinion will come with it.  Make sure you engage the PTO seasonal lever on the left of the seat before pulling apart.  Here are some manual pages I copied for someone else.
