snap coupler lift latches
old school allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote old school allis Quote  Post ReplyReply Direct Link To This Post Topic: snap coupler lift latches
    Posted: 10 May 2020 at 6:37pm
does anyone have any advice for removing the rivets to replace the springs because in my experience if they break off your out of luck
1957 d14,1963 d17 series 3,1963 d15 series 2,ca,c, 2 b 10's,and a big ten
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 9:23pm
Grind a flat place on edge of head and work spring over it.        MACK
NE GA Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NE GA Allis Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 9:46pm
MACK I think he is talking about the rivet itself, not the spring on the rivet.
Keeping Allis alive with:
2 B’s, 1 C, 6 CA’s, 2 WD’s,
1 WD45, 3 D15D’s, 1 D17
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 9:50pm
They are hardened drive screws. They are a pain to get out. Heating them with a torch will soften them. A vertical mill is best to get them out. HTH Tracy
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 9:56pm
I just did two sets.  I clamped a good set of vice grips on the rivet heads and just started rocking them back and forth until I could feel a little movement. Then took a hammer and knocked them out by hammering on the vice grips from the back side and they popped right out.  Installed the new springs and drove the pins back in with a dab of red Locktite on each one.
D14JIM14 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (1) Thanks(1)   Quote D14JIM14 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 9:35am
I had D17 that the latch rivets were very rusted and bent . I wanted to replace them and couldn't work them out . So I heated the with a torch and melted candle wax on them and they came out with a little twist very easily !
Post Options Post Options   Thanks (0) Thanks(0)   Quote old school allis Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 10:23am
thank you for the great suggestion
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 4:55pm
I've seen a lot of them that were snapped off at auctions, so you can't get ahold of them.  I don't have a mill, so now what?
Post Options Post Options   Thanks (0) Thanks(0)   Quote old school allis Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 5:11pm
the last set that i did i heated them up until they were red hot and let them slowly cool down and they were soft and i started to drill them out and then i used a bolt extractor (bad idea) but it snapped off. so  no i have a snap coupler lift latch with a bolt extractor stuck in it. so now i am just going to try welding the rivet head back on and filing a it down so i can get the spring over it
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 5:30pm
Ideally, I'd heat them cherry red, then as they go to cool, stick a bees wax candle against them, let the wax wick its way in.  Then set a pair of vice grips on them, real tight, and wiggle back and forth. most of the time, this works for me...Wink
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 10:44pm
What size drill bit?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 10:53pm
Pretty sure the carbide cutter I use is .218 diameter, or 7/32. If broke flush, you can carefully weld a nut on them, let it cool and twist it out. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2020 at 5:52am
Anyone ever see an 'after market' clone of them ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote old school allis Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2020 at 6:45am
djs tractor parts is where i usually get mine
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2020 at 8:19am
I did mine a couple years ago on WD45. Grind a bit off the rivet head - very carefully. Force the washer off. Once the washer is off get new exact size washer. Install spring and repeen. Was lots of material left to repeen. Did excellent job and I replaced all 4 springs. I’ll maybe see if I can post a picture later. Take your time. Have it in a vice to make it easier.
