AC D19 Gas Fuel Pump
MDWilliams338 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MDWilliams338 Quote  Post ReplyReply Direct Link To This Post Topic: AC D19 Gas Fuel Pump
    Posted: 11 Mar 2020 at 10:35pm
Anyone know where ,if such an animal exist ,to get a rebuild kit for D19 fuel pump or buy a new pump? These pumps look very,very similar to the Airtex-ASC pumps and I may give the techs there a call and see if I can match a pump if I have to go that route.Any help would be appreciated.
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2020 at 7:21am
I just picked up a rebuild kit for my D19 fuel pump at AGCO last week they are available
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2020 at 7:27am
Use a electronic pump or no pump at all.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote MDWilliams338 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2020 at 7:54am
Ok thanks,good to know.I tried looking through their PDF catalog last night for it or a part number and my patience skipped out on me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2020 at 7:36am
I can get the part number for you later today if you wish!
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2020 at 9:16pm
Just out of curiosity, if a fuel pump isn't really needed, why did ALLIS put them on so many models of gas tractors? I'm aware of the majority of the models have their fuel tanks higher than the carbs for gravity flow, but surely there's a reason for a pump ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MDWilliams338 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2020 at 5:17am
Thanks and I appreciate it but dad got it ordered from his friend that owns our local ( used to be AC) dealer yesterday so all good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2020 at 6:19am
The fuel pump is an absolute necessity for a 6 GPH steady flow of fuel in hills and low fuel levels in the tank at 100% load.  Don't believe it ??? Try and plow with 2 gallons of gas in the tank and see what happens.
Captain Positive View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Captain Positive Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2022 at 1:55am
If you still have that part number handy, I'd love to get it from you (and/or a link to the website would be helpful too!)
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2022 at 6:32am
Check with one of the many places that rebuild antique car fuel pumps. If the pump is screwed together most any place will rebuild it. There are a few places that rebuild the band clamped pumps.  They now use rubber parts that stand up to Ethanol in the gasoline. A mechanical pump is the safer option unless you wire it in with an oil pressure switch. If something happens you don't want that electric pump to continue pumping gas.
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2022 at 6:43am
I have a kit on hand for those pumps.
