185 Starts, stops, have to prime again.
Samos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Samos Quote  Post ReplyReply Direct Link To This Post Topic: 185 Starts, stops, have to prime again.
    Posted: 27 Jan 2020 at 11:07am
My 185 has been hard to start for quite a while now, have to use starting fluid. Now she needs priming she will then start run for 30 to 90 seconds and stops. The priming pump will have no resistance until I pump it a few times. Checked all the fuel lines tightened the connections. I found a diesel leak on the Roosa Master DBGFC 637-4JN  (4024596) injector pump, where the throttle shaft enters the pump. I would like to rebuild the pump even if this is not causing my starting issues it still needs fixing.
I need help, would a roosa service manual for D or DB be the correct one to buy and which service kit or kits should I buy. Would it be best to strip the pump first to find out which parts need replacing, assuming I can tell.
Thanks in advance.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2020 at 11:10am
Remove the sediment glass bowl. Turn the petcock on 100%. There needs to be TWO STREAMS of fuel gushing from the sediment bowl base. If not, the base needs to be unscrewed/removed and unplug the blockage of debris. While you're there, throw away the screen. If this isn't the problem, loosen the two flat blade screwdriver screws on the side of the injection pump and let it leak. Then, see if it stays running with a slight fuel leak.
Edited by DrAllis - 27 Jan 2020 at 11:12am
Boss Man View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2020 at 6:02pm
Unless you have the calibrating equipment I would just remove the pump and send or take it to a diesel specialists. The primer pump could be causing the leak down all so. I would start by replacing the primer pump and see what happens. They were a real sore spot on some engines
Dave in il View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2020 at 5:48pm
Sounds like the hand primer, between the 190XT, 200 and 7060s I always kept a repair kit handy in my pickup. Actually there's still one in the center console, lol
AGCO My Allis Gleaner Company
troym View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote troym Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2020 at 7:17am
pull the return fitting out of top of injection pump. if it remains running the pump is building pressure and cant release. there is a glass ball and spring in there that sometimes pluges with the rubber from the governor slip ring. it gets old and deteriorates.
bradley6874 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2020 at 8:14am
Listen to what the dr said ...... A 185 has the fuel tank under the hood and above the primer and injection pump if it's sucking air its not getting fuel flow from the tank also if the return is pluged up its hard to prime cause you cant push air back to the tank
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2020 at 8:20am
exactly what happened to my 185.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2020 at 9:10am
You have to start with the fuel flow/sediment bowl first. Then, move onto the glass ball. Leaving the window loose on the pumps side helps diagnose whether the glass ball is plugged or not.
m16ty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2020 at 8:52pm
A manual for a DB is what you want. Just replacing the throttle shaft seal is super easy.
You can also find reprints of AC injector pump manuals.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2020 at 1:28pm
The primer pump on my 190 gave out and the dealer in Gibson City refuse to sell me just the plunger stuff!--Said that I had to buy the whole pump at a cost of $ 185 at that time so I went down the street to NAPA and got an electric one for $ 50 and junked the manual one and put the electric one in its place. Never had a primer problem after that.
Also stuff can get in the tank and plug the sediment bowls, sometimes requiring tank removal and cleaning, then work down from there with lines/filters.
As for tearing into the injection pump,----better leave that to the guys that rebuild them! IF you open it and can't get it back together, you will now need a new pump because the shops won't undue your screw-up. ---Its your pump so do as you like!
Ilikeallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ilikeallis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2020 at 5:09pm
this happened to mine, how long can this go?
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2020 at 9:31am
All these post and he still hasnt said if he has fuel flowing out of the tan or what he found
Post Options Post Options   Thanks (0) Thanks(0)   Quote Samos Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2020 at 8:03pm
Settle down bradley6874, I work in remote locations, long days, long shift, no grantee of internet. I checked the sediment bowl and had fuel flow there. That's as far as I have got -25C is not fun. I appreciate the advice. I like the idea of and electric fuel pump to replace the primer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Samos Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2020 at 8:10pm
Just happened to talk to the wife's cousin he's worked for Finning for ever. He 's going to come over and have a look. I had a similar issue before when the tank was rusting it would clog the sediment bowl up. had to remove the tank and use POUR 15 to coat the tank. Part of the problem could be waxing due to cold, its warmer at home now. I guess I will find out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Samos Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2020 at 10:54am
Yesterday Saturday Feb 8 -20C, Drained all the fuel out of the tank, Two nice streams from the sediment bowl. Removed the fuel filter warmed it in my shop, emptied out the fuel and filled it 50% with conditioner anti gel. Opened up the small timing cover to empty more fuel out. Put it all together. Poured the rest of the conditioner in to the fuel tank with new diesel and another conditioner/injection cleaner. Opened the sediment valve, fuel didn't fill the bowl until I pumped the priming pump, then it gushed in. Started the tractor with either and she ran.
I cleared snow for about 30 to 45 minutes (seemed to be lacking a bit of power) then she stopped. I opened and checked the fuel cap for any suction as I opened it, didn't here any suction, would not start. Usually when I crank her I get white smoke from the exhaust which I assume is unburnt fuel,  but not this time.
Put the battery charger back on, I will have a go tomorrow as long as its not too cold.
I will check the check ball in the return line as well.
Any ideas?
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2020 at 11:23am
Remove the check ball from the return fitting on the top cover of the injection pump. You now are fairly certain you have a good supply of fuel. You did leave the screen out of the sediment bowl, right??? That is the FIRST place they will gell in the wintertime.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2020 at 11:36am
As Dr Allis said, knock the ball out to get by for a little while, until you can be down for a bit to get the pump properly serviced. While us pump guys are not geniuses by any means, the do it your selfer projects don't usually end well. I really don't like working on pumps the owners first tried to "fix it myself". There's no substitute for the experience!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Samos Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2020 at 3:11pm
Thanks guys I'm heading out now, I didn't see a screen I seem to remember I removed it a long time ago. I think I will try to start it right away, if it runs for a while then stops it will tell me that pressure is building but I will remove the ball after the test. I will let you know.
Cheers
