Rotary chopper gear box?
twinsonfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinsonfarm Quote  Post ReplyReply Direct Link To This Post Topic: Rotary chopper gear box?
    Posted: 13 Jan 2020 at 11:55pm
I need a new gear box for a old Brillion RSS72 72" rotary chopper.  Who makes a good quality replacement?  Probably needs to be around 40-50hp gear box.  Used with an Allis WD45.  Thank you, Jim.
Edited by twinsonfarm - 14 Jan 2020 at 12:19am
CaseyCreek View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CaseyCreek Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2020 at 6:36pm
I don't know the bolt pattern on that model. Depending on how much modification you are comfortable with, you could have a lot of choices. If you get lucky and have a modern four or six bolt pattern, you could be up and running pretty quickly. Omnigear makes gobs of gearboxes for several rotary cutter manufacturers. Going from memory, the RC 161 is about a 70 hp gearbox that I have seen sell for between 175 to 275 depending on whether or not I needed one at the time :-)   try surpluscenter.com.
D17 Series III,D17 Series IV, 185
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2020 at 9:03pm
get your specs, off the one you have, then check surpluscenter.com...Wink
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2020 at 9:55am
