CA Restoration-remove water pump pulley
Dale (Stonelick) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale (Stonelick) Quote  Post ReplyReply Direct Link To This Post Topic: CA Restoration-remove water pump pulley
    Posted: 10 Jan 2020 at 1:21pm
How is a fan belt pulley best removed from an old water pump?  I have a new replacement water pump that didn't come with a new pulley.  I tried a gear puller but was concerned about bending the old pulley.  I have used a MAPP torch and have it sprayed down with penetrating oil.
If a new pulley if needed, who sells these?  I couldn't find at Steiners, US Ag Parts, or Amazon.
Gerald J. - I looked in the on-line manual but it does not indicate how a rusty pulley can be removed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2020 at 1:25pm
I gently tap around the edge perpendicular to the shaft while turning it.  After you get it loose, you'l need to turn it a 1/4 turn to get the adjustment bolts to pass the hub.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale (Stonelick) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2020 at 11:19am
PaulB:  Thanks.  I kept torching, oiling and tapping and it finally came loose.  After the 1/4 turn it was still hanging up, so I cut off the extended stove bolts and punched the heads in.  The part cleaned up real nice with a brass wire wheel.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2020 at 11:30am
Thumbs Up
