Adding a coolant filter to a 7010? |
allispicker
Topic: Adding a coolant filter to a 7010?Posted: 05 Jan 2020 at 8:37pm |
Has anyone added a coolant filter to a 7010? If so what kit did you use and where do you plumb it in? TIA
DrAllis
Posted: 05 Jan 2020 at 9:56pm |
Use the correct antifreeze and there's no need for a coolant filter.
HD6GTOM
Posted: 06 Jan 2020 at 1:00am |
What antifreeze do you recommend for my 200. It already has a coolant filter. Thanks Tom. How are you getting along with the project tractor? I would like to see it when you get it done.
Gary(WI)
Posted: 06 Jan 2020 at 7:12am |
I have a coolant filter kit that was on a 301 from a combine I can find it and send pictures to an email if interested
DrAllis
Posted: 06 Jan 2020 at 7:23am |
Heavy Duty diesel coolant from any Caterpillar or Cummins dealer is what you need. Has a dark pink color to it. Using the proper coolant versus a filter, eliminates at least 6 places you could have a leak. There's are several reasons no one uses a filter anymore. One is, finding a place to mount it.
DO NOT USE THIS COOLANT WITH A FILTER !! SHUT THE FILTER OFF OR REMOVE IT.
Edited by DrAllis - 06 Jan 2020 at 7:24am |
exSW
Joined: 21 Jul 2017 Location: Pennsylvania Points: 914 |
Posted: 06 Jan 2020 at 7:52am |
Mine came with a coolant filter. Combine engine. I can take a pic if you want. I can tell you that filter isn't cheap. You may want to spend the money on better antifreeze.
Edited by exSW - 06 Jan 2020 at 7:53am |
Learning AC...slowly
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8995 |
Posted: 06 Jan 2020 at 9:14am |
Just be sure to get the green stuff TOTALLY flushed out first!
Meanolallis
Posted: 11 Jan 2020 at 9:28am |
DrAllis, I’m assuming/think Rotella ELC (more red) is the same stuff and would also work well...? Why don’t use a filter with it? Because the filters have additives in them that the ELC coolant doesn’t need/want? I suppose you could use a filter without the additives in it...?
Edited by Meanolallis - 13 Jan 2020 at 9:23pm |
DrAllis
Posted: 11 Jan 2020 at 9:54am |
As I understand it, there was/is more than one type of coolant filter. To continue to use it AND use the treated antifreeze could result in an overdose of the chemical that prevents cavitation erosion (pit holes in the sleeves) and turn the coolant into what looks like butterscotch pudding, clogging the cooling system and causing catastrophic engine failure. You do what you want.
Meanolallis
Posted: 11 Jan 2020 at 4:11pm |
DrAllis, That’s what I was thinking. Thank you!
Pete from IL
Joined: 29 Dec 2009 Location: Beecher IL. Points: 314 |
Posted: 13 Jan 2020 at 7:44pm |
Yes a coolant filter is available without any chemical charge in it. A Baldwin B5134 has no chemical charge and you won't have to worry about butterscotch pudding.
A Baldwin dealer may not stock that filter but they can order them for you. I use them on an 8070 with a factory coolant filter base and on a 7000 and 190XTdiesel with an add on coolant filter. It keeps your coolant rust and particle free.
