D-17 Muffler
JD-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JD-Ohio Quote  Post ReplyReply Direct Link To This Post Topic: D-17 Muffler
    Posted: 17 Nov 2019 at 2:25pm
D-17 gas serial number 33833. DJ.s and Steiner.s list a muffler for serial numbers less than 32000, and one for serial numbers greater than 42000. But nothing for the numbers in between. What gives?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2019 at 2:56pm
There are only THREE mufflers for a D-17 gas. The original muffler was the exact same as a WD45,  was round, and attached with 2 bolts and was about 3 inches in diameter and this was prior to s/n 32000. The next muffler clamped to a pipe coming out of the exhaust manifold, and was round and about 4 inches in diameter and was prior to s/n 42000. The last muffler from s/n 42,001 and up were the OVAL muffler and is considered a series 3 or 4 muffler. This all being said doesn't mean someone hasn't changed manifolds or cut larger holes in the hood to accept something different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2019 at 7:00pm
The oval factory muffler was the nicest. Quiet power.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2019 at 7:31pm
Would sure like to find an oval Nelson muffler for a D17 series III. Nearly impossible though. They sounded so nice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2019 at 7:49am
If you find a Nelson to a 180/185, graft that onto a D-17 gasser and you'll love the sound it has with less back pressure. The body is the same size. You just have to make a pipe adapter to slide over the pipe on the exhaust manifold to get things to match up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2019 at 6:44pm
Thanks Doc, good to know. I really miss that Nelson sound.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2019 at 5:45am
I see Steiner carries the Ovals, how do these sound?
Charlie
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2019 at 8:22am
Life is simpler when you plow around the stump.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2019 at 8:48am
JD
Check out Nelson 18202T.
They cross reference it to Allis 70261975.
Gary
https://www.simplyfilter.com/18202t-nelson-global-products-muffler-p/18202t.htm
or this one   05388t
https://www.simplyfilter.com/05388t-nelson-global-products-muffler-p/05388t.htm
Edited by Gary - 21 Nov 2019 at 9:09am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2019 at 4:53pm
Thanks for the ideas guys. I'd love to find an oem oval Nelson with the offset outlet like they came with back in '63.
