D 10 v D 12
Kiwi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kiwi Quote  Post ReplyReply Direct Link To This Post Topic: D 10 v D 12
    Posted: 17 Nov 2019 at 3:31am
Hi all just reading a book by Alan C King about the D 10 and D 12 and I can not see the difference between the two is there any other then 1/2 inch in height and length
chuck linn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck linn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2019 at 4:22am
D10 is 1 row tractor d12 is two row tractor has to do with row width spacing
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2019 at 5:38am
did the D12 come with high-low tranny, or was it an option ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2019 at 6:12am
They both had the HIGH/LOW trans as an OPTION and not in the early models.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2019 at 6:16am
Only difference is the wider rear side pieces, I forget the correct part name, its the piece between the rear and final drive...Wink
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2019 at 6:48am
D-10 and D-12 are identical tractors except for the width. As was said before, the D-10 is a one row tractor and the D-12 which is 11.5" wider is a two row tractor. Early ones had a 138 cu.in. engine and NO live PTO. Later ones had the 149 cu.in. engine and independent live hydraulics and PTO. An optional high/low range transmission was available on the Series III models.
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2019 at 6:44pm
Look at the steering linkages at the front axle, left side. The d12 has more parts.
Google up images of both and compare.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2019 at 7:05pm
I have a '65 series 3 D-10 with the 2 speed gear box in front of the 4 speed transmission. It will do 16.25 mph.
I like taking it on caravans. It is easy to load on my flat bed trailer I tow behind our class C motor home.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2019 at 7:28pm
Brian, you are correct on the steering linkage. D-12 has an extra pivot point to accommodate a wider front axle tread width setting
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2019 at 5:18am
My D12 on the left has a wider stance the D10 on the right
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2019 at 6:15am
Just so there's no misunderstanding about the optional 2-speed gearbox. It was an under-drive, not an over-drive. So none of the original 4-speeds are any faster, only slower.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2019 at 7:19am
underdrive .. great,, that's what I'd like to have to run the 5' rototiller !
The D-14 is a tad too fast....
course I'd have t find a D-12 and build another shed to hide it..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2019 at 7:38am
I think if you compare the ground speeds, under-drive 1st gear in the D10/12 is the same as low side of 1st on a D14.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2019 at 7:38am
Folks,
 Again I learn something about these small Allis D series tractors too! Nice! Great picture of the two side by side! Thanks Charlie!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2019 at 7:55am
To add some more differences, mainly in the Series 2 to 3 change
Fenders, lights, nose weight, foot pedals, controls
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2019 at 7:57am
More stuff
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2019 at 7:59am
and some more
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2019 at 9:47am
You are right. I had assumed that it was over-drive, I had to dig out my manuals and check.
Sixteen and two tenths mph is a pretty speed for the hp.
Thanks,
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2019 at 9:47am
Awful purty there Charlie, have the twin to your D12 with the live pto and live hydraulics, though some swear they did not exist that early.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2019 at 9:51am
The nose weight was an option, along with the grill guard. I have both, thanks to Snowman, He built both.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2019 at 10:03am
The weight is much needed on the front!
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2019 at 10:28am
Never drove one. With that gearshift shaft bent like that, do they shift OK?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2019 at 10:51am
Yes, same gearshift as a D14/15 has.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2019 at 10:53am
Forgot to mention the Throttle is different as Allis went with a different brand than what it had before.
One is push and one is pull. Makes for remembering fun when hopping on them
Charlie
Kiwi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kiwi Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2019 at 12:48pm
thanks for all the posts i want one now it might be a one day thing
RMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMD Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 5:29pm
4th gear in a CA, D-10 or D-12 is definitely a road gear. I remember when I was a kid that our CA would run circles around the other tractors on the road when going farm to farm to cultivate.
Edited by RMD - 25 Nov 2019 at 5:29pm
MDWilliams338 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MDWilliams338 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 6:36pm
Those are great looking tractors!! I spent many summer days hauling tobacco with a D10.Perfect for the drag middles and smooth sailing from the fields to the tobacco barns.
