WD45 water pump?
rustyorange45 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 water pump?
    Posted: 16 Nov 2019 at 9:29am
Need to change my water pump, it's leaking from the seal. Can a new seal kit be ordered to rebuild the old one? Researching water pumps and found a bunch of new ones anywhere from $50.00 on up. Where are the new water pumps made? China, India, Taiwan? Where can the bent pipe be bought? The pipe that screws into the water pump and runs to the thermostat housing. Thanks, Tim
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
mike a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike a Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2019 at 10:39am
i have bought rebuilt pumps with bad results-they leaked out of the same seal.bought new ones for about $120-end of the problem.auto parts store is where i found mine.i do not have a clue where they are made.good luck
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2019 at 3:51pm
Didn't see anything on my new D 15 water pump . Which does look good I should say . Sure was easy to see USA on my old pump . Thanks
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2019 at 5:08pm
use the old one' fix it' most of them out there are junk.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2019 at 5:16pm
In fact a lot of the parts out of the U.S. are of questionable quality according to my mechanic on my cars, so I guess it would hold true on a lot of the tractor equipment.    Leon
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2019 at 6:45am
I have bought several new ones and they all worked fine. I looked for a rebuild kit, so far I haven't found any. A bypass hose is available through Agco or other vendors. I stock them also. Use a pipe nipple in the pump.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2019 at 10:03am
I bought the $50.00 new water pump, was made in India. Is it going to be any good? Time will tell. I used the tractor all day yesterday bush hogging, cutting wood and piling brush. No leaks yet!
Edited by rustyorange45 - 17 Nov 2019 at 10:07am
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2019 at 12:28pm
Put aftermarket no core knock off on WD couple years ago. Seems to be ok. Was cheap enough. As Rusty says,time will tell.
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2019 at 6:01pm
Hmmm... Not sure where it came from, but my one WD has a new water pump from circa 2006 and the other one a new pump from circa 2009. They both seemed to work well.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2019 at 6:22pm
Never had one of ours get returned.  Kits are no longer available to rebuild.  You can go on eBay and buy from a seller there and hope you get something good, or buy from one of the retailers here and know that we have been around a long time.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2019 at 6:23pm
Our pumps certainly are not $50.  But then I suppose the other sellers know what their product is worth Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2019 at 5:06pm
I gt one from Jim D several years ago for the B. I used it 3 years or so, before I sold it with no problem from the water pump. Ya get what ya pay for, sometimes not, when you use fleabay.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2019 at 5:35pm
After market is after market. You can pay what you want. Higher price does not mean quality. Even Agco sells after market. Just my opinion.
REEDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote REEDE Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2019 at 6:16pm
I have sold HY-CAP reman water pumps for years and have had  very few problems.
For my two cents.
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2019 at 9:56pm
I'm not carrying a grudge here but l bought a new pump (from an advertiser on this site) and was told they are made in Turkey. I installed it with the cooling system staying dry while the tractor was parked in my shop (shouldn't really be any different than the pump laying on a parts shelf). A couple of years later I filled the system and ran the tractor with the water pump leaking generously out of the seal and out of the gasket on the back. Needless to say I was very disappointed but given the time from purchase 'til startup I thought it was pointless to let the seller know, I wouldn't expect it to be replaced anyway. On my other tractor (a WD) I replaced the water pump at least 25 years ago and it's still 100%. That was a rebuilt one from an automotive parts store. Now they don't have listings for them any more.
