7010 Cab Kit Recommendations?
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Topic: 7010 Cab Kit Recommendations?
    Posted: 11 Nov 2019 at 9:43am
Looking to fix up the cab floor, foam and headliner this winter and see that there are many choices.
Looking to see if anyone has recently done a cab kit on a 7000 Series and what product did they use? Thanks.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2019 at 12:04pm
Its not a 7000 series but I did an 8070 with a kit from Fehr cabs and am very pleased
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2019 at 12:25pm
Fehr
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2019 at 1:24pm
A few years ago I bought a floor mat from AGCO and the cab foam off Ebay, I have always had good luck with factory parts and don't mind paying a little more for quality.  Well that floor mat only lasted about a year and it started to crack along the length of the cab, after about 1.5 to 2 years it was cracked all the way through to the insulation in 5 or 6 spots.  I bought a shifter boot from sandy lake for the 6080 and it didn't even make it a year and it was all cracked and broken, now it is in about 4 pieces.  Now all of these tractors set under cover when not in use.  I then bought a cab kit from Fehr for another unit and it has been great for I think about 4 years now.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2019 at 1:36pm
I put Fehr kits in 7045 and maroon 7060. Both live in the same conditions but the 7045 has some peeling of the vinyl from the foam in just a years time. Some of the glue has let loose and I think that it might be just and application error. I would use them again. Got some different adhesive to fix the loose stuff. Also some panels had exposed foam on the edges so I trimmed it back and rolled the vinyl over it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2019 at 1:47pm
[IMG]uploads/13956/Resized_20190513_201510.jpeg[/IMG
A close up of some of the peeling. Also note the panel under the seat. They are different depending on which seat base you have. I compared the two kits and they let swap a couple panels. The other one got the wider panel for a better look..
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2019 at 5:12pm
Ferh is a good choice. Used them on both combines and both 8070s. Very happy with product and will use them again. Be sure to state you have a black belly tractor. They are different from the maroon belly kits.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2019 at 10:02pm
Used Fehr on 8070 and F2. I'm happy with them.Don't know what anything else is like.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2019 at 4:36am
Fehr does good work on cab kits. If you feel something isn’t fitting right, call them & they will talk with you about it. Here’s their AC 7010 products weblink.
https://www.fehrcab.com/search.php?category=1942&search_query=%227010%22§ion=product&_bc_fsnf=1&brand=38
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2019 at 11:02am
I'd like to find a floor mat that is closer to the original style. The new floor mats I've had crack.... especially if you have to pull it out in cold weather. The old mats were layered with a thick pad underneath. I think the old padded ones kept noise out better too.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2019 at 11:32am
Thanks for the guidance. Fehr it is then. Many people above say that is the way to go.
I suspect I need to do a good job on cleaning the old foam and/or adhesive off. Is there a good product that I need to use to do that? Don't want to kill myself with fumes doing it though! I would like to freshen up some of the paint inside cab, but that has the same issues on smelling paint for a long time in the cab. Any good ideas on that task?
I will try the floor mat from Fehr too. I am wondering if I could build up an extra layer underneath of the floor mat to help make it last longer?
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2019 at 12:15pm
I started using the 1/2 inch cow mats.  Takes a little planning and effort, but ii will probably be the last one you need.  Do it in two sections.  Have it in the 200, N5, and the 7080 is next. Saber saw and hole saw.....The 200 mat was gone and I put it right over the metal floor. really cut the noise.  The 200 was the first one and I did front and rear section, but should have done right and left section because of the under the floor battery box. It does not move around, buckle, or crack.....Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2019 at 12:24pm
Dale,
Sounds like a good idea. I have some of those stall mats from TSC on hand. I will have to make a pattern even if I cut it into two pieces. I will take advice on left and right, instead of front and back. Appreciate the idea. Now that I think about it, I believe I saw those stall mats used on some restorations at the Portland tractor show in Indiana last year.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2019 at 12:29pm
Great idea Dale.
I am going to try that on my New Holland 1114 swather.  It is one noise machine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2019 at 3:06pm
I like using 3M adhesive remover for taking off old glue residue. You should wear a respirator if you do. In my case I also used wire brushes to get the rust and dirt off. I don't think those surfaces were painted where the foam panels were glued on. Wore a dust mask for that. Surfaces must be clean to give the new glue a chance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2019 at 3:11pm
Thanks for the 3m Adhesive remover and rust removal tip.  Hate to do all of this and watch it peel off again.
tom51 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom51 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2019 at 9:32pm
Used conveyor belting from your local gravel pit or stone quarry works well also most times it's free it not worn out
