6060 pto housing
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Topic: 6060 pto housing
    Posted: 30 Oct 2019 at 11:05am
The hitch holes were broke out on mine when I got it and I have a good replacement housing. What do I need to look for removing it. Will the pto shaft stay with the tractor? Any advice and experience is appreciated. Scott
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2019 at 9:10am
Here is picture of one I did a while ago with the PTO housing removed.
I did not take a picture of the PTO setup.  The long shaft will stay with the housing, it slides in just above the ring gear so leave room to pull the assembly out about 2 feet.  NOTE make sure you engage the PTO lever on the left side of the seat, if not the collar will fall down when you pull it apart.  You do not have to take off the top 3 point shaft housing, I had that off for reseal already.  I use anerobic sealer for reseal on it, the factory used silicone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2019 at 9:00pm
Thanks, I was thinking I needed to engage the pto clutch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2019 at 7:25am
You need to engage the coupler disconnect to the left of the seat. If you don't do that, the coupler will fall down into the housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2019 at 7:22pm
Ok I reread the post thanks to both
This page was generated in 0.291 seconds.
