rare 70-52 plow |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24883 |
Topic: rare 70-52 plowPosted: 19 Oct 2019 at 7:09am |
OK, I've got my '70-53' plow almost all dissassembled which I'm converting into '52'. Silly question. Should the 'beam and blades' section U-bolted to the 'pipe' be able to rotate relative to the 'triangulare piece with the beaming screw ? Sorry for the non correct terms... Also shold the Snap-Coupler bar be centered between the 2 plows, it was(is) inline with the center plow of 3. Thanks yeah you can laugh.... Jay |
jaybmiller
Posted: 19 Oct 2019 at 8:55am |
hmm, I figure the collar between the uprights is the 'positioning adjustment device'...yeah the thing with a square headed set screw that's been rusted in place for 50 years or so ? THAT should be 'fun' to loosen and remove.. so far I've bused TWO 1/2" rachets getting things unstuck ! Jay
Gerald J.
Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
Posted: 19 Oct 2019 at 9:18am |
Laterally you want the left side of the right plow bottom to be inside the rear tractor wheel by the width of the plow bottom whether its 2 or 3 or 5 bottoms. So you keep the hitch the same, just remove the left bottom and its shank from the three bottom frame and hitch.
Gerald J. |
jaybmiller
Posted: 19 Oct 2019 at 11:11am |
so the 3 hour workout I got this morning I really didn't need ??? sigh... oh well... guess I'll see how humpty-dumpty goes back together..... heck, it's fun, warm-cool, sunny, quiet.... Thanks for the edumucation ! |
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5060 |
Posted: 19 Oct 2019 at 12:04pm |
On our 3 bottom snap coupler plow we used on out late model WD, to change from 3 bottom to a 2 bottom, you removed the 2nd bottom and moved the 3rd to where the second was. This was because the third bottom had a much longed land-slide.
Dusty
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8625 |
Posted: 19 Oct 2019 at 2:22pm |
Jay,
I made one old plow from two old plows. I went through some of the same frustrations. Trying to get parts freed up and working. I can tell you that if you want to plow with it, the time to fix it is worth it! Even hooking it up was nice because I could adjust the SC hitch on the plow up or down to back into the SC bell on the tractor. I think its time for some pictures! Regards, Chris
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8281 |
Posted: 19 Oct 2019 at 2:53pm |
make sure the tractor you use to plow with, you have the wheels set at the correct width.
jaybmiller
Posted: 19 Oct 2019 at 5:40pm |
Thanks for the comments guys ! I'm just trying to make a saleable 2F plow. After 1/2 day of heat and oil still can't get the beam to rotate on the big bar. Maybe the frost tonight will help ?? lol... At least it now LOOKS like a 2F plow !! I'm hoping it'll free up once it's back in the dirt, where it belongs. Cheers Jay
bigfish_Oh
Joined: 13 Sep 2009 Location: West Liberty,Oh Points: 1226 |
Posted: 19 Oct 2019 at 6:36pm |
I've always said the difference between my plows and your real plow is my beaming screw works ! ![]() |
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe 1951 WD, factory p.s. 1960 D14 HnMk IV BkHoe 4 sale 2014 HD Tri Glide 2009 GMC CC SLT Dually |
