Gaskets
miketothesteve View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote miketothesteve Quote  Post ReplyReply Direct Link To This Post Topic: Gaskets
    Posted: 08 Oct 2019 at 5:52am
My questions apply more so to a B, but could also be considered general.
Are people buying gasket sheets and cutting your own, or buying pre-cut gaskets?
I believe the gaskets are cork; has anyone used a different material?
Does anyone know what the gasket thickness is for the B?
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2019 at 6:32am
I usually buy gaskets, but I've also made some. There are a couple for my WD45 that I couldn't find so I made. I made some cork ones for my skid steer last year. There a big cover on each side for the chain drives. Case wanted like $30 per side, so I bought a roll of cord for about $30. Made both sides with some left over.
I'm not sure on a B, but on a WD45 there are some places where gasket thickness is critical because it set gear mesh. So just watch out for that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2019 at 9:00am
It totally depends on which gasket you need. Material and thickness is dependent on the use of the gasket. You can't make a thick cork gasket for an oil pump, and a thin gasket won't work well on the oil filter housing.
 I wouldn't even think about trying to make a head gasket, or one for the rocker cover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote miketothesteve Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2019 at 10:40am
I likely need to replace the gasket around the oil pan. And the gaskets for the carb. What would you recommend?
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2019 at 12:01pm
If I can buy it, I buy it.  I hade some for the thermostat housing because the shapes are simple and I had the gasket paper.  I would not take on anything much larger or complex than those, myself.
1951 B
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2019 at 12:13pm
Go to www.djstractorparts.com and buy the gaskets you need.  Great to work with.
AaronSEIA
