D17 Series III Alternator Conversion
jeickman01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeickman01 Quote  Post ReplyReply Direct Link To This Post Topic: D17 Series III Alternator Conversion
    Posted: 04 Oct 2019 at 4:05pm
This conversion is a project like many others on my Series III that I have researched and stored parts for until my retirement.  Unfortunately I didn't take very good notes.  I thought that I could use the later model 175 alternator brackets but it's not going together and lining up with with the crank pulley like it should.  The brackets bolt up fine to the front engine support.  I must have seen this on the forum years ago - maybe it was just an orange dream.  And I can't seem to find it in a search.  Does anyone who has done this with the 175 brackets have any pictures?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeickman01 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2019 at 4:14pm
Sorry - it's a gas, not diesel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2019 at 7:32pm
One-Seventy gas water pump and crank pulley are the same location as a gas D-17, so your lower alternator brackets should be fine. The D-17 upper tensioner bracket has to have a notch cut in it to clear the power steering pump and leave the cooling fan off of the alternator (for power steering belt), assuming you are using a Delco brand.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeickman01 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2019 at 8:21am
DrAllis - you are right.  I was trying to mount the smaller Denso alternator which, of course, was not the 170 stock unit.  It appears that everything will line up with the Delco unit.
