A430 corn head divider sheets
Ben (MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Topic: A430 corn head divider sheets
    Posted: 21 Sep 2019 at 7:55am
On my A430 corn head the divider sheet pins don't quite line up with the holes because I am sure they are all a bit tweaked. To save frustration during harvest I want to drill out the holes just a little bit. Will I regret doing so? Thanks.
Part time farming with a 1980 7060 and 1984 F3 hydro.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2019 at 7:20pm
Which "pins" are you talking about? The ones that drop into the "frame" and you pop a hairpin into the hole in the pin? We just "man handle" the offending row unit until the 2 pins line up. Perhaps your dividers are tweaked worse than ours?? We run the same head BTW Big smile . Have a safe harvest !!
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2019 at 8:51am
I second what FREEDGUY says. I also run an A430 and with a little friendly persuasion they will go where they're supposed to unless something is majorly bent.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2019 at 9:01am
Yes, the pins that hold them in place. I am sure I have something tweaked. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2019 at 10:36am
I wouldn't enlarge them. Fix what's wrong
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2019 at 7:11am
What SteveM says..... make it easy and untweak them.
Wink
I am a Russian Bot
