Looking for a little help
Darrell G (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Topic: Looking for a little help
    Posted: 03 Sep 2019 at 7:40pm
Is the power director unit the same on a D-14 as a D-17?
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2019 at 9:05pm
no
if you look them up in the AGCO parts books, you'll see the difference
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2019 at 1:40am
The D17 has more clutch plates
Owner of Matt Scott LLC
http://www.mattscottllc.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2019 at 5:42am
makes sense.... more power needs more plates to transfer the energy....
same parts though ?? just curious...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2019 at 2:31pm
no
The PD clutch housing halves on a D14/D15 vs D17 are different.
Again, spend a little time and check the AGCO parts books.  You'll be glad you did.
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2019 at 10:04pm
The shims are interchangeable (long & short of course), the plates are interchangeable, the pressure plates at each end are interchangable, the brass shift collar is interchangeable, the cast input end housing is longer on the D17, the output end cast housing has a bigger spline for the D17 transmission, vs the D14/D15. Also the # of plates are different between the D14/15 and the D17 but the plates themselves are interchangabel from the D-series power directors-100 series power directors-100 series hydraulic PTO clutches.
Hope that helps
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2019 at 10:06pm
Also the 3 long shifter spacers are not interchangable as they are different length between the D14/15 and D17(longer), the center plates between the shims are interchangeable
www.awtractor.com
