autolite generator
NNYACAL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NNYACAL Quote  Post ReplyReply Direct Link To This Post Topic: autolite generator
    Posted: 03 Aug 2019 at 8:04pm
I recently purchased a CA with a replacement 125 power unit engine in it. It has a magneto instead of a distributor but it runs fine but on the other side it has a very small auto lite generator with a cutout on it. Would this have been original equipment or a replacement generator someone has put on it? It looks factory but i have never seen one before. Any information as to the wiring or testing would be appreciated.
NNYACAL
G,IB,B,C,CA,RC,WC,WF,WD,WD45,D14,D17SERIES 1,2,4
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2019 at 8:33pm
If 12 volt it is a replacement. But with the cut out it is very likely a 6 volt and original. Allis used both Delco and Autolite generators and starters so either one could be original.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NNYACAL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2019 at 8:48pm
i BELIEVE IT TO BE 6 VOLT AND IT IS STILL POSITIVE GROUND BUT CAN'T BE SURE ABOUT THE GENERATOR SOMEBODY HAD PUT AN OLD 12 VOLT BATTERY IN IT AND WHEN I PUT A NEW BATTERY IN IT THE FIRST THING IT DID WAS TO BREAK THE BENDIX SPRING WHICH IS COMMON. SURE WISH I COULD FIND SOMEONE WHO STOCKS THE NEW RUBBER CUSHIONED BENDIX.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2019 at 5:17am
I have some NOS bendix springs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2019 at 9:39am
Early CA's didn't have a distributor. They came with a magneto. I imagine power units were the same way, probably even after the distributor was standard on the CA, because you probably didn't have a starter, generator and battery on power unit applications.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NNYACAL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2019 at 10:29am
Are parts for this autolite generator still available and does someone on the forum stock them? I would like to keep it all original if possible.
 Sure hope next year at the GOTO here in northern New York that some vendors will come and even maybe have a few people put on some brief seminars during the show. Any one interested in doing this please just send me a message on the forum.
NNYACAL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2019 at 12:02pm
If anyone has parts it would be Steve. https://www.bb-customcircuits.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2019 at 4:40am
I also have a bunch of NOS Auto-Lite armatures. If you tell me the number on yours, I may have a match.
This page was generated in 0.184 seconds.
