2 bottom SC plow
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Topic: 2 bottom SC plow
    Posted: 26 Jul 2019 at 9:42am
I need another plow like I need a hole in the head, but I don't have a two bottom and I couldn't live without one any more. Thanks Facebook Marketplace.
I assume its a #52 plow, but I am wondering about the solid lift link on the left side? Never seen (or noticed) one before. Don't see anything in the manual about it, and the manual covers both pin hitch and SC type.
So there, another one saved from scrap.  Any info would be appreciated. I have a three bottom SC plow, the WD pulls it OK in first gear, but its a handful when you get into a wet spot. This one should be a breeze in second.
Thanks for looking.
The mechanic always wins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2019 at 9:48am
I've got a 3 btm, same 'solid bar' setup. I was going to make it a 2 btm as one pointy piece is busted and still, after 6 years ,haven't got around to welding a patch in. I should just sell or 'find a new home' for it but Murphy says my 3 btm will need parts.....
Jay
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2019 at 10:12am
Not sure but it might be a model 63 with the slanted beams the bottoms are mounted on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2019 at 10:18am
#62. Two bottom. A #63 would be three bottom
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2019 at 10:39am
yep, a #62! I have a few plows that have the solid lift link on the left side.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2019 at 11:33am
OK, so where does the 60 series come into play? Is the 60 series an improvement that replaced the 50 series?
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2019 at 12:48pm
And what is the "shock shoe" for? It's a little piece on the landside that swivels on a bushing.
Edited by littlemarv - 26 Jul 2019 at 12:48pm
JoeO(C-MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(C-MO) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2019 at 1:11pm
That always seemed backwards to me, since the operator usually dismounts on left side , walk around the plow across a furrow, on plowed ground, bend over further making the adjustment.
In my opinion, why not make the adjustment on the land side!  IMHO
Edited by JoeO(C-MO) - 26 Jul 2019 at 1:14pm
D10 III, D15 II 3 pt, D15 II SC, 170 Gas w/shuttle, 175 Diesel UI ROPS, 185 w ROPS. AC 653 w/6 way blade, ROPS
AC 615 Ind. WD45 running/Parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(C-MO) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2019 at 1:17pm
just that, keep from breaking/bending the share point if plow drops too fast
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2019 at 5:54pm
As you can see from the pics, a 60 series has better trash clearance...
Well since There is no pic of a 50 series, take my word for it, the 60 series with the bent shank just clears trash better...Wink
Also uses a more modern, straight share...WinkWink
Edited by DiyDave - 26 Jul 2019 at 5:59pm
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2019 at 10:13pm
There is a post over on the Knowledge forum about plows with detailed descriptions of the various AC families of plow frames and a link to a plow frames parts book and a plow bottoms parts book.
Gerald J.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2019 at 10:17pm
Congrats on a fine purchase. I feel your pain!! I can't help myself either, bought a model 52 back in April, that I REALLY needed.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2019 at 10:31pm
I noticed the solid link on a plow here at Hutch today...I know very little about plows..it just seemed to stand out
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2019 at 9:01am
I'm speculating a bit here, think the non-adjustable link was just a cost reduction move on AC's part. The adj. link on only one side achieved everything needed and way cheaper to produce. For us, two less threads to rust solid to have to free up!
