Allis 200 Tractor Pump Timing Issue
smitty78 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitty78 Quote  Post ReplyReply Direct Link To This Post Topic: Allis 200 Tractor Pump Timing Issue
    Posted: 08 Jul 2019 at 10:31pm
My ole 200 tractor continues to bring gray hair ... seeking opinion.
Removed pump and injectors for overhaul after turning engine till marks in pump window aligned and timing mark on gear cover was at about 20 deg BTDC.  Did not turn engine while waiting for rebuilder.  Did remove the pump drive gear cover plate but 90% sure I did not disengage those teeth from idler gear teeth.  Reinstalled pump and injectors, bled lines, started tractor, and it sounded pretty good, but white smoke.  As I waited for it to warm up, diesel started leaking from the exhaust manifold so I shut it down knowing unburnt fuel was present.
  So what have I done ?  Messed up timing ?  Injector issue ?
Please refer pics for clues ...
The idler gear has a timing dot but the pump drive gear doesn't have a dot that I can see, but does have a helical shaped mark around the rear face.  Is this a timing mark ?  Service manual shows a dot aligned on both gears when timed correctly.
With the pump timing marks aligned and the pointer on 18 BTDC per service manual, the dot and helical don't align.
Also, it doesn't look to me like the injectors are seating properly even though I verified no crush washers left behind and new ones on each injector.  Are they supposed to sit this high ?  (I removed foam dust seal for the photo)
With the roosa marks aligned and on 18 BTDC the idler gear dot is out of position.
I never had the drive gear off the shaft but perhaps inadvertently slipped some teeth.  So, any ideas on how I can get this back into time would be appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 10:55pm
if the pump times at 18deg and that pointer is there and the pump marks are lined up,it should be in time no mater what the dot says.  Always check timing marks vs deg pointer after turning engine by hand in direction of rotation to eliminate any gear backlash. That helical is a machining mark from a sloppy operator. Can't explain the raw fuel. With pump and injector rebuild,that should not happen.
Edited by SteveM C/IL - 08 Jul 2019 at 11:03pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote smitty78 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 11:25pm
Thanks, I do turn it by hand the direction of rotation.  Since it ran pretty smooth, as if the timing was close, I wondered if some of the injectors weren't seated so they were just squirting fuel from the wrong position, therefore incomplete combustion.  They were torqued to spec.  Per the photo, I can't see anything down there that would be preventing them from seating properly, and the new crush washer is crushed, but they just don't feel right so will check again.
Also, 90% sure the outer shiv on the harmonic balancer hasn't slipped in the rubber which would put the timing marks out of position.  Haven't found the alignment marks on the dampner with a mirror but still looking to verify.
With injector # 1 out, and the dampner timing mark on top dead center, the piston is up, but valve cover not removed to verify valve position.  Is it possible the pump is out such that it is injecting at top of exhaust stroke ?  Don't see how it could run that way but that would push plenty of diesel out the exhaust manifold.  Also I'm confident the drive shaft dot was aligned correctly when stabbing the pump onto it.  Ugh I hate puzzles.
Edited by smitty78 - 09 Jul 2019 at 6:14am
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2019 at 6:53am
I would pull injectors and have them rechecked. Sounds like one is stuck open or end blew off.     MACK
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2019 at 8:21am
11GR times to 24*. Your rebuilder should be able to offer some guidance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitty78 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2019 at 8:19pm
What does "11GR" refer to ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2019 at 8:26pm
DBGFC 637 11GR...….every digit/letter means something.  11GR describes what type of timing advance that is built into the pump.  The static pump timing differs with the type of automatic advance. Some model 200 tractors are timed at 24 degrees BTDC and some are timed at 18 degrees BTDC.  IF FOR SOME REASON THE ADVANCE HAS BEEN ALTERED BY A PUMP REPAIR SHOP, THEY ARE TO REMARK THIS INFO SO THE PUMP GETS STATIC TIMED PROPERLY.  Timing an 18 degree pump at 24 degrees will eventually burn piston bowls.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2019 at 10:18pm
Remove #1 injector line at the pump.  Look in banjo bolt hole for presence of the discharge hole. The hole will just be present on the edge of the bolt hole when it is about to fire the injector . Think of this as the same as a rotor button on a distributor.  locate this hole and then check your timing to see if it is 'close'.  A sluggish engine that has white smoke and fuel out the exhaust usually means severely retarded timing - or one that is 180 degree out - yup they will that way but usually hard starting and ruff running.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitty78 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2019 at 10:32pm
I saw a service bulletin but it didn't expressly include the 11GR and I didn't know which listed version was applicable.  But I will ask the repair shop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2019 at 9:31am
The 11GR was first, then came the 3JN with same 5* advance. Then AC wanted to go to the 8* advance so the engine could be timed down to 18* instead of 24 for easier starting. The 7JN and 10JN are essentially the same, just the position of the line in the window is altered.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2019 at 9:44am
Ed, on some of the 185/200 with good batteries , starter , cables etc, the last run of pumps that were designed to crank better, had a fubar.  The cranking speed was improved, then when fuel was injected it almost would crank at a high cranking speed but the auto advance kicked in full at cranking speed thus killing the advantage of the retarded timing. AC had us buy that timing tool that fit on the window and had the peg that fit in the cam ring groove that gave the exact advance movement - then had us turn in the trimmer screw so as not to advance until about 900 rpm best I can remember.  We had several units that this cured the hard starting..  Timing advancement at cranking speed (transfer pump psi) will make any roosa hard to start.
As a rule of thumb if the factory seal is broke on the bottom timing advance trimmer screw, some one probably has tried to turn more fuel to the unit not knowing what they were doing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitty78 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2019 at 11:38pm
Allis 200 now set at 24 deg, started easily but still have 1 injector streaming fuel I guess because white smoke exhaust and fuel running out of exhaust.  Loosened the exhaust manifold and determined it to be cylinder 3 or 4 so I'll pull them and see what the heck.
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2019 at 6:24am
Not to be a busybody, but a cold (wet) cylinder can be easily detected by pointing a infrared laser heat gun on the exhaust manifold while running
No need to loosen anything...
Has turned out to be one of my most valuable tools. The dead cyl is quickly detected
About $23 at Auto Zone or Harbor Freight.
Edited by JayIN - 28 Jul 2019 at 6:25am
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitty78 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2019 at 5:52pm
Thanks JayIN, I think I have one of those, I'll look for it.  Now time to admit I'm a fool ...
Took the injectors from the wet exhaust manifold, sent them back to the shop that repaired them, then sat back rehearsing my speech on how they should pay attention to their work.  They were returned with a note saying injectors were fine, just plugged up with anti seize.   Oops ... once I had an injector connection gall so I like a bit of anti-seize on the connection.  Since I wasn't paying attention I let it get into the tube and plugged newly rebuild injectors ... foolish but that's me.  Still have some white smoke but no moisture in the exhaust path so hoping any other plugged injectors will clean up with fuel additive and time.  If not, I'll take them back to the shop, tail between my legs.
Now however, I have one more question for the experts.  Power steering is intermittent (hard to turn) and the hydraulic pto, when driving a brush hog, stops in medium heavy weeds.  Is this likely a flow or pressure problem ?  (System is full of clean fluid, new filter, and rebuild pto valve.
Thanks for any advice.
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2019 at 11:08am
I can just add this, my 185 was missing, sound bad, took the pump off sent it off for rebuild, reinstalled, sounded great until I bumped the throttle up above 2000 rpm and she started sounding bad just like before, the old man who rebuilt my pump said man I am sorry I should have had you check the roll pin.  If you take the front plate of of the 185 the gear is on a tapered shaft going to the pump and has a slot with a roll pin in it, the pin had sheared allowing it to slip the timing.  Replaced the roll pin with a new one for .25 cents and she has been great ever since.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitty78 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2019 at 10:45pm
Can anyone guess why the hydraulic driven pto "slips" when driving a brush hog in light to medium weeds ?
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2019 at 1:00pm
Could be a bad o-ring.
Had this happen to a 180 tractor.  We bought a new Vermeer hay baler.  The pto would stall.  The Vermeer dealer was there and checked over the baler.  Nothing could be found wrong with the baler.  Hooked up another tractor to the baler and it worked properly.
Took the tractor to the Allis dealer and put it on a dyno.  The problem turned out to be a bad o-ring.  This was thirty years ago. They changed the o-ring and the PTO is still running strong.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2019 at 8:26pm
May be a hydraulic pump issue. My 190XT had notchy steering, especially if below 1,200 rpm, rear end would slip and then grab if I locked either brake in a tight turn(like when you plant corn with a 3point planter to go the opposite direction). Not sure my hydraulic pto ever slipped because it ran a square baler fine. Anyway, sent my hydraulic pump to SLI and they rebuilt it. It had a lot of wear in it and required a complete rebuild. Resolved all my issues after I installed it.
This page was generated in 0.176 seconds.
