WD45 Headlight Lens Gasket
TimCNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimCNY Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Headlight Lens Gasket
    Posted: 22 Jun 2019 at 8:58am
AGCO P/P 70209832. I know they're available, just wondering if anyone uses something else like black RTV, etc. or if anything other than the gaskets is even advisable to use. First time changing bulbs. The wiring was a disaster when I bought it, lights never worked before. Now the entire electrical system is new, with the exception of the starter but that was rebuilt a few years back.
Time for a new battery, too (12v). The old one isn't holding a charge, but it was enough to connect and show that the lights and voltmeter work! Discharged quite quickly though and not enough juice to produce more than the annoying >click-click-click<. So, second question - the old battery is significantly bigger dimensionally than the "new" battery box. Any particular battery recommendations? We have an excellent battery shop in the area but just wondering what other people have been happy using before I get to them next week.
Thanks!
- Tim
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2019 at 9:57am
I would definitely NOT recommend RTV!  The lens will seal to the frame.  If you need to change the light bulb that is behind the lens down the road, you will probably wind up breaking the lens.  Gaskets are cheap compared to lenses.
For the battery, I measured the inside of my battery box and then looked for a battery that was close to those dimensions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimCNY Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2019 at 10:16am
I agree DSeries4, the P/O used RTV so I was wondering about that. I was lucky getting things apart. Just ordered a set.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2019 at 1:55pm
I think someone posted some pics, many years ago, of using black 12 gauge wire.
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2019 at 6:31pm
  A group 24 top post battery should fit in the  6 volt battery box with no problem.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2019 at 7:00pm
Gaskets are available after market. I stock them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2019 at 7:57pm
I find that the short fatter group 22 works better than a group 24. Just don’t get the tall skinny 22. Get the proper headlight gaskets, you’ be happier than doing a kinda works fix.
1939Dodge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1939Dodge Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2019 at 8:22am
When installing gaskets, make sure the seam is at 6 o’clock, to drain any condensation.
