Are there Bailers the WD won't power?
acisbest View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote acisbest Quote  Post ReplyReply Direct Link To This Post Topic: Are there Bailers the WD won't power?
    Posted: 10 Jun 2019 at 8:26am
Hello,
I have about 10 acres which is mostly wooded. Maybe an acre of field that I brush hog from time to time and also use the tractors to Skid large logs out of the woods.
My neighbor rang my bell yesterday. He has a sheep farm with about 17 acres. His tractor blew up and wanted to know If I could help him bail his hay.
I have a D17 but it's hooked up to my Mcconnel Backhoe and I don't want to unhook it. My WD is available and it has a 3 point hitch attached to the snap coupler.
I've seen him bailing, it's a small square bailer, it might be a New Holland and I forgot to ask him exactly what it was. I'm hoping the WD will power it.
I'm sure the WD will power the side delivery rake.
I told him I would want to operate my tractors since they are old an temperamental.
Do you think I'll be ok with the WD?
acisbest
AC HD6G, C, CA, WD, D17, G
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 8:31am
should work as long as  you arnt pulling loaded wagons on hills with the baler.  you didnt mention any accumulator setup.  Remember,  if the wd is too fast or the windrow is too big,  you can use the hand clutch and keep the pto chugging.
Edited by CAL(KS) - 10 Jun 2019 at 8:33am
WF owner View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 8:57am
I've baled a lot of hay with a WD (and always pulled a wagon behind). The only (minor) problem you may have is hydraulic hookups, if the baler has a thrower.
Ranse View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 9:01am
A good running WD should handle a baler just fine. 30 hp is all you need. I pull one with my D-10. A WD is heavier, I'm not sure if it has a D-10 beat horsepower wise by much, but it should handle a baler.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 9:03am
Unless it has some kind of hydraulic accumulator or something, a WD will easily run any plane jane square baler ever built.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote acisbest Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 9:25am
Ok, good information, thanks. It's a flat field and I can't remember if he ejected the bales into a trailer or just dropped them on the field. If he drops them I'll have to de-hitch the D17 because it has a trip loader.
nella(Pa) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 9:29am
My WD will run my JD 24T with no trouble, if you have hills, rake and bale on the contour if pulling a wagon. Bale the hill section with an empty wagon and fill the wagon on the level section of the feild.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 10:09am
My Grandpa's opinion was that the best hay-making tractor ever built, was the D17... the power steering, ergonomics, and power-director being the three main reasons... but I'm absolutely certain the WD would have no problem covering the need, as long as hydraulics weren't needed.  It'll be good work for it... they stay cleaner inside when they get worked well every now'n then.
TimCNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimCNY Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 1:58pm
Considering that back in the 60's the New Holland balers on two of the farms on our road were powered by Wisconsin engines, I can't see the WD being underpowered...
Robert Musgrave View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Musgrave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 2:32pm
As a kid on mostly flat ground, we ran a New Holland Super 68- "A hay in a day" machine- with a WD45 but I think a WD would also  be capable; we used the WD to jockey empty wagons back to the field.  We also would rake with a steel-wheel ground-driven rake using a Model B or the WD.  R. Musgrave
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 2:52pm
Some of the high capacity balers, like the Hesston inline baler, take a  considerable amount of power, but the average square baler doesn't take much.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 6:04pm
I baled with the CA and pulling a wagon behind for years without issues. A WD will handle a small square baler no problem. If the tongue starts bucking you're going to slow.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (1) Thanks(1)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 7:36pm
Baled with Dad's WD and a NH 268(?) for years. Never had any problems running out of power. Usually baled all summer long for Dad and 2 of my uncles.
1951WDNWWI View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1951WDNWWI Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 9:34pm
We baled hay with a H Farmall,  six less horse power than a WD, on a New Holland 66 baler.  No problem at all.  Like a previous post said if you start 'bucking' you are not feeding the baler fast enough.  We would load 120 bales to a load.  You did not want to find a badger hole with the wagon.  Fast way to unload.Ouch
JohnCO View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 11:44pm
I baled thousands of bales with my CA and MF #10 baler back in the '70s.
Allis Express participant
Post Options Post Options   Thanks (1) Thanks(1)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2019 at 6:08am
acisbest,
 We need some pictures! You should not have any issues as others have mentioned. Baled with WD and 45's with New Holland 268 balers for years. Hand clutch is a great tool for this project.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2019 at 6:26am
That H was over powered if it had 6 less than a WD. Most H's had about what a C had and could hardly pull the hat off your head. They were good for backing a wagon though. I remember baling for a neighbor every summer with a WD45 6 volt that he always had to hand crank and then he had this H for pulling the wagon. It could barely pull a full load but it managed. No elevator to stack hay in the shed so he climbed each bale up a few levels to me then I would climb them up a little farther and stack them. Dad always offered to bring over our elevator but as long as he had me working for him I guess he figured we'd get by..... and we did.
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2019 at 6:34am
Here you can watch what the little tractors did back in the day. Second video has balers
[TUBE]ys29TVxIVQA[/TUBE]
[TUBE]VT98KorMKYQ[/TUBE]
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2019 at 6:38am
Lonn,
You do have a tag line!Smile
its: "I have no tag line"
Just thought I would throw that out there!
Thanks for the Allis videos too.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2019 at 6:44am
I had a better one but not PC enough I guess. Oh well, not my website. It had something to do with a certain Medieval religious leader and it was a true statement. You'll have to use your imagination as to what it said.
Edited by Lonn - 11 Jun 2019 at 6:47am
Wink
I am a Russian Bot
allisbred View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2019 at 6:58am
What Baler will you be using? New Holland makes balers that a wd would have problems moving(560 or bigger) without weight on the front end and they made many like a 273 that are “feather” light and anything between. My 45 would have the power for my 315 but think it would throw me around a bit, not to mention the wear on the pto.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2019 at 8:29am
We did thousands of bales with WD45 and New Holland 270 baler and  wagon on behind. Had some hills as well but not real big hills. Usually 120 to 125 bales on full wagon same as Lonn. Tires were loaded of course. I really like how it worked. Later we had a MF165 diesel which was a bit heavier. I preferred the WD45. The pto speed on the MF seemed a bit slower. Had to run throttle it up lots.
Post Options Post Options   Thanks (1) Thanks(1)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2019 at 10:18am
...and the quick governor on the WD45 really helped when you got into heavier hay.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1951WDNWWI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2019 at 1:17pm
  This H was a little different.  Dad bought it in the early 70's and it had been the IH dealers personal tractor.  He drove it to work.Smile  It had a loader on it and duals and it would do 28 MPH on the narrow front end.  Dad bought it without the duals.  We thinks it was 'cranked' up a little.Wink  One time running from a neighbors place to home pulling a full load of hay I passed an IH 656 pulling a baler and wagon on a paved county road.  Should have seen the surprised look he had.LOL
Edited by 1951WDNWWI - 11 Jun 2019 at 1:23pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2019 at 1:41pm
I think everyone that looks at a “CA” as being to small to do any real work should watch the second video as it cuts and bales hay with a wagon being pulled behind to boot. Just goes to show you don’t need a 100 hp tractor to get the job done.
Thanks & God Bless
Dennis
RMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMD Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2019 at 3:44pm
But note that all the bailers in the second video have there own engines - they are not powered by the tractor's PTO. I can remember my uncle bailing with a Ferguson TO-30 that way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2019 at 3:51pm
Some of the Amish around here use an old baler with a Wisconsin engine behind a horse drawn fore-cart.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2019 at 8:36pm
The CA has plenty of power to run and pull a baler with wagon.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (1) Thanks(1)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2019 at 9:02pm
Back when I was about 14, I used Dad's CA to pull the 14T baler, pto powered, and a hayrack behind. Never had a problem with it, though it was on mostly flat to rolling hills.
EPALLIS View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2019 at 9:18pm
I ran a WD with an International 46 for years. I did add one set of rear and front wheel weights with that big fly wheel in front. At the end of the day it handled it all just fine even pulling a wagon load of square hay bales as well.. Hope that helps. Thanks!
