185 Engine Dieing, Believe to Be Fuel Problem |
AC7040
Topic: 185 Engine Dieing, Believe to Be Fuel ProblemPosted: 09 Jun 2019 at 6:33am |
Hello all. Neighbor has a 185 diesel with a roosa master fuel pump. When I grind feed or just drive it down the road im having trouble with low engine power, engine rpm fluttering, and the engine dieing. After 15, 20mins of running the engine will begin to show the signs listed above and eventually die. I've changed fuel filter twice, sediment screen, drained fuel tank, checked on fuel flow from tank and all is good. When the engine starts to lose power, it make take 2,3 mins before it dies, when it dies I simply push the start button and it fires right away and will run great for another 15 20mins before going through the same problems. Does not smoke, no fuel leaks. I'm leaning towards something sticking in fuel pump... If it was a fuel flow problem I don't believe I'd be able to start it right away and run great and would have to prime fuel system. But you guys are the experts so I'll take your advice. Thanks!
1953-WD45, 1949-G, 1950s Snap-Coupler All-Crop Drill, 1956 Roto-Baler, 1945 All Crop 60, Snap Coupler Subsoiler, Plow, Gleaner F, 505 wagon
Beirnesy
Joined: 30 Jun 2012 Location: Mid Western Ont Points: 351 |
Posted: 09 Jun 2019 at 6:38am |
Read this link, it may help |
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
DrAllis
Posted: 09 Jun 2019 at 7:19am |
On the top cover of the injection pump, there is a rubber hose connected to the fuel return line. Remove the rubber hose from the injection pump fitting. Remove the fitting from the brass elbow on the pump (takes 7/16" wrench). Take this special fitting to a bench grinder and lightly grind on the very end of the threads to loosen up the crimp that holds the washer in place. Pry out the washer, remove the glass ball, and remove the small spring. BLOW air thru the fitting to be sure it is open. Reinstall on the pump and if the tractor now runs fine, it is soon time for an injection pump overhaul. You can nurse it along like this for a while, but plan on some downtime and expense to repair the pump correctly.
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5204 |
Posted: 09 Jun 2019 at 10:56am |
seems like a weekly thing. Great advice from the Dr, as always. I rebuild a lot of pumps just for this issue! Modern fuel attacks the flex ring in a much shorter time than the old days lol!
exSW
Joined: 21 Jul 2017 Location: Pennsylvania Points: 914 |
Posted: 09 Jun 2019 at 11:15am |
Yep. No just an AC issue it's a,Roosa Master issue. Same thing happened in my 706. Same diagnosis,same fix with the return check ball. Same answer. Buy new pump.
allisorange
Joined: 27 Mar 2010 Location: perkins, michig Points: 381 |
Posted: 09 Jun 2019 at 1:32pm |
Had that happen with are 180. Needed a pump rebuild like Dr. said. Once the pump is rebuilt problem will go away. John Carlson
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Posted: 09 Jun 2019 at 2:06pm |
When these pumps are rebuilt due to flex-fail, are they repaired with an "up graded" part? We had the pump rebuilt on the F2 for this same reason.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35666 |
Posted: 09 Jun 2019 at 2:26pm |
My own 180 did fine cleaning the return fitting until absolutely died, then the pump went to the shop.
injpumpEd
Posted: 09 Jun 2019 at 5:40pm |
When many shops "rebuild" these, they only put a new flex ring back in, because they want to see the pump again in a few years, of course once it's out of warranty lol! 99% of the ones I do here in my shop do get the EID weight retainer, which appears solid, bit is still 2 pieces cushioned with rubber bumpers inside. The rare occasion I put another flex ring in is a parade only, or museum tractor.
AC7040
Posted: 16 Jun 2019 at 10:18am |
As always THANK YOU ALL for sharing your knowledge and experience! I've been told by the neighbor The fuel pump is being rebuilt at a local shop that he's used before so fingers crossed they fix it right 🤞 hoping to get to run her when she gets back
