aftermarket wide front for a WD
wide View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wide Quote  Post ReplyReply Direct Link To This Post Topic: aftermarket wide front for a WD
    Posted: 03 Jun 2019 at 5:39pm
I've been seeing a few wide fronts with the round tubes.
 They might be schwartz or something like that.
 Here's one for sale:
 https://desmoines.craigslist.org/grd/d/saint-charles-allis-chalmers-wide-front/6891749725.html
Are they better than the stock wide fronts?
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2019 at 8:49am
wide, if you're looking for a wide front end for a WD, I have a 4-bolt I will part with.
Don't know too much about the aftermarket ones other than I don't care for how they look.
Edited by IBWD MIke - 04 Jun 2019 at 8:50am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2019 at 9:16am
They don't turn as short as OEM and look like crap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomstractorsandtoys Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2019 at 4:35pm
DrAllis has it right. There are plenty of factory ones at reasonable prices why would you consider one of those. Tom
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2019 at 6:46pm
I have never been around a WD with after marked front end but have been around JD and IHC. Do not put a loader on one. Spindles are not heavy enough.
wide View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wide Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 6:06pm
Thanks for the info.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 6:20pm
that one is gone!
I am still confident of this;
Wait for the Lord;
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2019 at 6:54am
They turn like lumber wagons..... or at least that what I was told but I've never driven a lumber wagon.  I have driven a WD with a Schwartz front end and I prefer the factory wide front purely for the maneuverability..... and looks!
Wink
I am a Russian Bot
wide View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wide Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2019 at 12:13pm
The one in the link looks like it has a platform for the front end to sit on.
 I'm not sure how the factory wide front is mounted but I think it's just a few bolts screwed into the cast material.
 I think that was the first thing i noticed,.. also the price is down to $100.
 Thanks for the info. Doesn't sound like it's better than the stock 4-bolt wide front.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2019 at 10:57pm
This is a Schwartz front end:But it's not installed the 'normal' way.
Normally, a Schwartz frontend of this flavor, would mount in such a way that the existing narrow-front steering pedestal was still in place, but with the wheels removed, and replaced with a steering arm that acts on rods to the steering knuckles.
The Schwartz company did NOT make front ends with the intention of being able to turn as tight as a factory WF.  They didn't even CONSIDER that as a concern... they built their front ends to make tractors strong enough to survive under the load of the Schwartz fully-hydraulic front-end loader... and be 'EASILY' installed and replaced from a NF farm tractor to change from wide-front manure-moving, to narrow-front picking corn... which AC, and virtually any other manufacturer, could NOT do.
While the factory wide front and narrow front may turn tighter, turning radius is a moot point when the nose of the tractor is on the ground with a broken steering knuckle, and a bucket of wet pooh  holding it down...  but I can assure anyone with no doubt, that the Schwartz (the one I own, at least) is substantially stronger than ANY of the OEM wide fronts prior to the D17...
