7020, 200 pumping 60 hours non stop
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Topic: 7020, 200 pumping 60 hours non stop
    Posted: 03 May 2019 at 7:24pm
Both have Murphy switches, both have been running non stop for the past 60 hours. We check the oil and refuel twice a day. Run both of them about 1500 rpm while pumping, the 200 runs a 14" vertical shaft pump. The 7020's pump is 16". Them 301's are so efficient on fuel. Not bad for 40 year old tractors.  We did shut both off tonight and will see what tomorrow brings.
 Mississippi river is supposed to crest tomorrow at 3rd highest in history here.
I'm ready for warm dry weather.......
Leon B MO
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 8:35pm
Nice tractors! Will be praying the rain stops in MO. 301’s were the best engine AC ever made IMO.
1852 Moore Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1852 Moore Farm Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 8:59pm
Those two units are moving some water. Where did u pick up your relift pumps? Been looking for a twelve inch model for water/flood control.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2019 at 7:59pm
What are you pumping out of.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2019 at 1:35pm
Bet that's a nice sound ! No better sound from an engine than a Allis 301 running on a pull
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2019 at 12:37am
folks around here plumb a 300/500 gallon fuel tank onto their tractors. you have 2 nice lookers there!
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2019 at 12:14pm
I am curious where you are pumping that water?  Is it going back in the Mississippi River on the other side of that levee?  The other pump looks like it is at top of Levee?
Don't live next to a river so this is all foreign to me, but you are moving a bunch of water with pipes that size!  I hope flooding has stopped.  It won't quit raining here in Indiana.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 7:35am
We are pumping water from inside the levy to the creek on the other side, which runs into the Mississippi . When the river is normal the water simply runs out though a pipe. But when the river level is high any rain water has to be pumped out.  Trying to keep the water off in case it ever stops raining long enough to plant.  The 200 is running a lift pump, I don't recall where Dad found it, but is has vertical shaft that goes down through a casing to the water, pumps it up and out.
Leon B MO
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1852 Moore Farm Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 4:36pm
If you run across any used camelback pumps in the twelve inch size, please pm me. Thanks and hope that the skies clear up.
soggybottomboy View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote soggybottomboy Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 6:48pm
  What is a murphy switch?
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 7:46pm
high water temp, low oil pressure needle hits the switches were they are set at and shuts it down
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 7:47pm
Murphy switches are a special oil pressure and temp gauge with limits that can be set that will automatically shut down the engine if the oil pressure is too low or the temp gets too high. Remember Murphy's law ? " if it can happen, it eventually will happen"
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote soggybottomboy Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 7:22pm
Yes,i know all about Mr Murphy,he sets up camp out here once in a while. thanks for your response. Next question is who sells them. I use my 200 on an 18 inch kelderman pump,and i always hate walking away and leaving it.
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 7:36pm
Most irrigation dealers should have Murphy gages on the shelf. Any place that sells stationary engines would probably have them. We have always used them on tractors and engines where you need safety units to shut down the machine for low water pressure, over heating, low oil pressure or level of oil, over heating motor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2019 at 7:08am
The one on the 7020 I got online after searching Murphy Switch. I has both water and temp gauges, override switch and test switch in a nice metal box. Gauges are adjustable for different shutdown setting's. Here's a couple of pics.
LeonB Mo
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2019 at 9:34am
So....what method is used to actually shut it down? A mechanical device that closes fuel stop? How is that powered?
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2019 at 9:57am
we have one on our 8550 and electric current holds a solenoid open.  when a gauge falls below desired operating spec a contact is hit inside the gauge and it stops the current and the solenoid closes shutting off the fuel to injection pump.  to start you push a button to bypass the shutdown until gauge reaches operating range.
Edited by CAL(KS) - 10 May 2019 at 9:58am
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2019 at 2:00pm
I found one on ebay that looks just like yours for $259 plus shipping although it says that the fuel solenoid valve is not included.  Looks like the Solenoid is about $110.  Both look high quality and certainly cheaper than a ruined engine.  I never knew these existed so thanks for the info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2019 at 9:27pm
Yes, you may have to add an electric shut off on your injection pump similar to the 80xx series or solenoids found on combine pumps.
Leon B MO
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2019 at 10:25am
Both of my 440's have murphy gauges in them, never could see need for that in them, but the factory put them in.
This page was generated in 0.205 seconds.
