200
otis3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote otis3 Quote  Post ReplyReply Direct Link To This Post Topic: 200
    Posted: 22 Apr 2019 at 6:40pm
how do i refill bullgear housing on a 200?i forgot
joe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joe Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2019 at 6:45pm
Don't you just refill the rearend? There's just two transmission compartments on that tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote otis3 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2019 at 6:50pm
dont think so.think they are individual compartments.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2019 at 7:24pm
Fill/level plug on each side of the rear end housing kind of behind the lower link arms. If the drain plug is 6 o'clock, the level plug is around 3:30.
Hurst
1979 Allis Chalmers 7000
5800 Hours
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2019 at 7:27pm
I am unfamiliar with a 200, but are you SURE it has bull gears?? I just assumed a 200 would have straight axles like a 190 ?? When I hear "bull gear", I am reminded of the best built tractor of all time= D-17 regardless of series #!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote otis3 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2019 at 7:54pm
icall the big gear,bull gear, but may be called a final.
joe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joe Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2019 at 8:43pm
Really? I was not aware of this. Does it take 821 or a gear oil? You actually have to fill it separately?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2019 at 8:55pm
Yes, they are filled separately. Either 80EP or 821.      MACK
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2019 at 9:00pm
The 2 "Final Drive" compartments; 1 on each side, hold oil for bull gears. Book calls for  8 qts each of AC #715 gear lube, I've been using a 75w-90 synthetic for about 25 years. I check mine every winter and change them every 3 or 4 years. I only put about 200 hrs/ year on it. You may need to partially remove the lower anchor pins for the 3 pt. cylinders to service them.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2019 at 7:05am
You're referring to drop axles. Both the D17 and 190 have bull gears. The 190 has inboard bull gear and pinion while the D17 has..... I suppose you could call them outboard bull gear and pinion but most around here call them drop axles.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2019 at 6:15pm
Thanks Lonn,I just recall dad taking the d-17 bull gear to a local welding shop to have a tooth welded back on to the main gear after it fell off of the jack while switching  tire/wheels for the N/I mounted picker  UnhappyCensoredShocked !!
It also "jacked-up" the PTO shaft, was never able to make a somewhat hard turn with pto engaged without shearing a pin !!
Edited by FREEDGUY - 23 Apr 2019 at 6:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote otis3 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2019 at 9:12pm
thanks guys for the info.filled both sides.had to raise the three point about 6 inches.made easy to get to plug.thanks again.
