7060 HYD. IMP. QUESTION |
Acdiesel
Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2592 |
Topic: 7060 HYD. IMP. QUESTIONPosted: 15 Apr 2019 at 8:29pm |
BUDDY'S GOT A J.D. 12 ROW CORN PLANTER WITH 2 PRESSURE LINES AND A RETURN,HAS ANYBODY GOT ANY GOOD WAYS TO HOOK UP THE OPEN RETURN TO TANK LINE ON THE 7000 SERIES TRACTOR'S OTHER THEN DUMPING IT IN THE FILL PLUG HOLE, AT THE REAR END?
THANKS FOR ANY IDEAS. DAN
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF D15 SER.2 DIESEL D12 SER.I, D10 Ser.II 2-720'S D21 Ser. II Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
DrAllis
Posted: 16 Apr 2019 at 7:06am |
Lower sight glass for one place, which is easy to do. The metal cover plate below the PTO and above the drawbar could be drilled and tapped into for a Pioneer coupler off to one side.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8981 |
Posted: 16 Apr 2019 at 8:18am |
If you're dealing with a vac planter post back how it works out. "They" say 7-8000's don't have enough hydraulics to run one.....
Acdiesel
Posted: 16 Apr 2019 at 10:43am |
great thanks for the tips.
not a vac system. dan
210Postin
Joined: 06 Oct 2016 Location: Ellisville IL Points: 151 |
Posted: 16 Apr 2019 at 9:16pm |
They will run a single motor, but not two dont leave much to run the rest of planter.
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3670 |
Posted: 17 Apr 2019 at 10:30am |
Thanks for sharing about the Vacuum planter motor issue. What factors contribute to the AC tractors’ issue with this? |
DrAllis
Posted: 17 Apr 2019 at 11:38am |
I'm assuming that 23 GPM doesn't meet todays new planter specs. Most modern day tractors are more than 50 GPM and some near 80 GPM's.
SteveM C/IL
Posted: 17 Apr 2019 at 12:13pm |
I don't get it but certainly don't know all facts. Read online somewhere specs on those fan motors taking 4gpm. Is that right? If true,how does that max out hydraulics? Is there not enough left to raise it? I know there are several lift cylinders.
210Postin
Posted: 17 Apr 2019 at 8:33pm |
Well a 7200 16 row with two blowers will take around 15 gal just for blowers ,have a pump doc pump on a 8050 ,pto pump cooler and flow controls to run mine .Tractor hyd run lift and markers thats how we run ours.
Unit3
Posted: 17 Apr 2019 at 9:56pm |
IF, if you were running GPS and Field IQ to turn on and off the planter, once you cross the inside end row, the meters will stop. If you turned off the valve for the motors, would the seed fall away from the vac plates?
If not, could you turn off the motor valve, raise the maker(if used) then raise the planter? We run a blue finger pickup planter and I know that doesn't count for much these days.
GM Guy
Joined: 31 Jul 2012 Location: NW KS / S.C. ID Points: 1988 |
Posted: 18 Apr 2019 at 1:46am |
Meanwhile there is a guy in SW KS running a 16 row central fill White with a 8070. :) He admits he shuts down the central fill blower to lift it on the ends though. Pressure planters take alot less hydraulics to run, much more friendly for older tractors. Edited by GM Guy - 18 Apr 2019 at 2:04am |
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help. |
lentsch
Joined: 10 Feb 2011 Location: Glencoe,Mn. Points: 236 |
Posted: 18 Apr 2019 at 9:50am |
Edited by lentsch - 18 Apr 2019 at 10:00am |
WD,D15,190XT,7000,8010x2,7060,8070
jiminnd
Joined: 16 Sep 2009 Location: Rutland ND Points: 2337 |
Posted: 30 May 2020 at 3:52pm |
Funny this just came up again, just had a neighbor ask this am if his 8070 had enough hyd to run a 16 row. He has a 12 now but wants to go to 16, would be a White planter, I know nothing about them, just this question.
210Postin
Posted: 30 May 2020 at 10:42pm |
Well we run a 6122 white bean planter 12 23 with the small pto pump to run the blowers has to be run at rated speed for 2.5 at gauges
