Brinly sleeve hitch
Slowmotion View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slowmotion Quote  Post ReplyReply Direct Link To This Post Topic: Brinly sleeve hitch
    Posted: 31 Mar 2019 at 3:51pm
I'm looking for a way to hitch Brinly sleeve hitch implements to my 5020. It has a tow bar and 3 pt. hitch. Has anyone done this? Are there adapters available?
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2019 at 4:24pm
Not the cheapest but  buy one of those 3pt hitches made to tow trailers with a receiver then weld  a sleeve hitch onto the hitch part that slides in that would normally have a ball on it.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2019 at 4:47pm
Make your own hitch.----That would be the best way.---There no specific factory adapters that I know of.  Make a simple A-frame on the 3-pt., then add the sleeve hitch to that, and you have an adapter that will use any sleeve hitch equipment. The lift arms would allow adjustment for level or tilt.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2019 at 4:59pm
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2019 at 5:11pm
If it were me, I'd find a piece of 2" thick-wall tubing, make a T, weld pins to the right and left sides, put a pair of tabs for a top pin, then weld two tabs near the bottom to serve as the sleeve pin...
What implement do you have in sleeve that's big enough to hitch up behind the 5020?
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2019 at 5:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2019 at 6:20pm
Corrected my earlier post for the  and one of these
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slowmotion Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2019 at 12:31am
The only implements I have now are a Ferguson bullet plow that's too big and a 42" Bush Hog with a jammed up drive line. I'm looking for a 1 bottom plow and a small disc, and I occasionally see used Brinly implements online.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2019 at 6:29am
I made my own,copied one from Ford LGT125 but...Brinly made 3pt implements as well as sleeve hitch. I've got 3pt plow and cultvator for my Sears ST12. Tod bad you're not a lot closer as they're collecting dust.
Check local ads, CL, Gogle search....ask at small engine repair shops, yard sales,etc.
Jay
