Case ih 5100 grain drill
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Topic: Case ih 5100 grain drill
    Posted: 10 Mar 2019 at 2:39pm
So I bought a 5100 grain drill last spring to plant my oats and beans. I love The thing to death except it has no guidance. No markers what so ever. The previous owner did install a couple chains in the front that you're suppose to use. That really sucks to keep looking back all the time. My thought was to add a couple markers.
Does anyone have markers on their drill? This is only 12 foot.
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2019 at 6:29pm
Put the chains on a bar on the front of your tractor and have chain just touching the ground. Make it so can make it narrow for road transport like the first 600 no till planters used in the 70s
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2019 at 7:28pm
I used the markers from an old international planter If I was to do it over I. Would set the light bar up to switch tractors for spraying to planter
Edited by bradley6874 - 10 Mar 2019 at 7:43pm
beard66 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote beard66 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2019 at 7:29pm
I have seen a few with markers, though not very common in my area. We used to pull a 21 hole 5100 with an ih 656 gas. We used a pipe on the front of the weight bracket with a chain hanging from each end that would lay in the drills tire track from the previous pass. Worked great with the flat smooth tires that came on the drill new.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2019 at 10:03pm
Buy a GPS and use it on every thing, or I will sell you a set of hydraulic markers off my 20 ft JD drill.       MACK
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2019 at 10:07am
Once you get used to how far away to drive from the previous row you just planted, you shouldn't need to look back. We (and most of our neighbours) have the same drill and none use a marker with 12 feet.
20 - 24 feet is when to use a marker.
