Hydraulic outlet
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic outlet
    Posted: 07 Mar 2019 at 7:47am
This winter is dragging on and I've finished just about all my jobs for the winter. Now I'm scratching for things to do. One thing is on my white tractors the hydraulic outlets really suck to get hooked up to. You have to pull the hose twords you then at the same time push your implement into the hose and then release everything.
Have you guys ever converted your tractors to something better? I was thinking something like John Deere has where you just push the hose in and you're done.
I looked at the valves all states offered with the handles on the valves to help in hooking up hoses with pressure on them but they want a pretty penny for them
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2019 at 8:07am
So why not plumb in the John Deere style that you like?
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2019 at 9:36am
Bob if you come over I've got a million and one things you could do. Wink
It's never ending with things for me to do. Cry
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2019 at 9:48am
I'm not impressed with the couplers on Dad's 4230! Like Pioneers a lot better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2019 at 9:55am
Really?  The JD conical style, with the lever under the coupling to turn flow on?  Huh....I LOVE those compared to pioneer, and wish Deere had never switched.  Yeah, they wear out over time and need parts, but when in good condition I really like them.
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2019 at 11:07am
The reason for the pull out to hook up allows the hose to unhook if caught and pulled or if you forget to unhook one of them btdtq
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2019 at 11:25am
They may be worn out, I don't know. They have come uncoupled several times on me. Not crazy about hooking them up either. Probably doesn't help that I just don't like John Deere stuff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2019 at 12:50pm
True, but the newer ones you can push or pull to release the balls, and will release for accidental causes like you just mentioned.  It's nice because you don't have to fight against yourself to pull out the coupler while pushing in the hose.  Push in to connect, pull out to disconnect, free to disconnect on emergency.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2019 at 8:06pm
I put couplers like Tbone95 described on my 200. Same as the ones on a Kubota 9540 and others. They work on the ridged outlet with an npt to o ring adapter.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2019 at 7:06am
The 7000 series couplers aren't too bad. The 7030 and 7050 weren't the greatest but many were updated to the later 7000 series. I have found that on some 7000 series the little lever or plate that you pull gets bent or doesn't have enough of a hump where the plate pushes the coupler. Easy to remedy IMO. I updated my brother's 190 from the type you mention to the 7000 series and will do my 200 this weekend.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2019 at 2:35pm
Thank you for all the help. I'm going to try and clean my couplers and try and mount them a bit better. We will see how this works this spring. I may be revisiting this subject this summer.
fourthgeneration View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fourthgeneration Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2019 at 8:13pm
I put Safeway push/pulls on the 6080. I had to mill a new plate out as they are a bit smaller diameter. I’m going to do the same on the 7020 and 8070. There is a fixed body that may be an 8450 that I may put on our 185.
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2019 at 9:49am
Does anyone make something like the later 7000 couplers. We bought a Steiger and it has all older Deere couplers and need changed out. I hate to spend what it costs for the pioneer lever couplers.
