F&H Spoked wheels |
R.L.Smith
Joined: 08 Nov 2013 Location: Roanoke, IN Points: 52 |
Topic: F&H Spoked wheelsPosted: 21 Feb 2019 at 4:06pm |
I have a nice set of F&H spoked wheels. casting number HC46A. I was told they came on early WC. I'D like to know of any other models they may fit. early UC, or early WF? Also told they have same bolt pattern as F&H HC3, and F&H HC26A wheels. Thanks for any advise. I plan on cleaning them up and sell, and helps if you know what they fit.
MNLonnie
Joined: 11 Sep 2009 Location: Baxter MN Points: 4797 |
Posted: 21 Feb 2019 at 7:19pm |
WC and WF are the only Allis they will fit. They fit Deere AR and BR and Farmall F20 I think.
ecclap
Posted: 25 Feb 2019 at 9:32pm |
The HC46A and the earlier HC46 wheel hubs were designed by F&H for the WC tractors. If you want to get real technical they do share the same 6 7/8" bolt pattern as the Farmall F-20/Regular F&H round spokes bearing the HC26A casting number. The John Deere GP Series, the AR/AO and BR/BO all used a 6 bolt pattern but it was 6 3/4". The Deere hubs were HC3 or HC128A. An Allis or Farmall hub in perfect shape will not fit on the Deere tractors without enlarging a couple holes but most of these F&H hubs have enough wear on them to swap right onto the incorrect tractor. They were never originally engineered to do so.
R.L.Smith
Posted: 26 Feb 2019 at 11:46am |
Thank you for the information.. I was not sure about the green tractor wheels.
ac fleet
Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
Posted: 26 Feb 2019 at 1:11pm |
I know they fit f-20 because I did it! |
