D14 Gas Line Shape/Routing
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Topic: D14 Gas Line Shape/Routing
    Posted: 06 Feb 2019 at 2:46pm
I have acquired a well-used gas line for my D14. It needs to be reshaped to fit properly. I'm wondering if anyone could provide an accurate drawing that shows the lines twists and turns. I've looked at the line shown in the parts manual - it doesn't provide much detail. Also, I assume that the line passes behind the air cleaner; is this correct?
Thanks very much!
Dave
WC, CA, D14, WD45
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2019 at 6:06pm
Dave I'll take a picture of the gas line on my D 14 tomorrow, and post it.    Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2019 at 8:00pm
Thanks, Tim!
Dave
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 4:01pm
So I took the oil cup off. I still haven't painted that gas line yet.  Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 9:53pm
Thanks, Tim. I think I need to rotate the sediment bowl 90* to reduce the sharpness of the bends in the line. Will have a look tomorrow.
Dave
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2019 at 3:53pm
Was able to look at the D14 today. The sediment bowl needs to rotate 180* so the gas line will run behind the side panel. The panel will have to come off - one of my least favorite things on that tractor! I'll make a list of a few tweaks that can be done with that off and get to it once the weather warms up a bit.
WC, CA, D14, WD45
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2019 at 5:47pm
Why the filter ,sediment bowl took care of one we had [ D 14 ]. since 57.My B stopped because of new type gas . Sealed screen in sediment bowl.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2019 at 5:54pm
there's at least 2 styles of sediment bowls, one has outlet 90* from the other one..I've got both on my D-14s so I can't say which is 'officially' correct.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2019 at 9:20pm
Good point on the different sediment bowl styles. Will have to check that before I get too deep into this.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2019 at 5:00pm
Okay! Today I pulled the side panel so I could rotate the sediment bowl and adjust the hood latch. After getting that done, I routed the line as shown in Tim's pictures and tightened both ends of the line. No leaks! She fired right up. Thanks for the help.
Dave
WC, CA, D14, WD45
