Putting spin out rims back on
Anthony View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anthony Quote  Post ReplyReply Direct Link To This Post Topic: Putting spin out rims back on
    Posted: 29 Jan 2019 at 6:45pm
Ok got a queston. I bought a couple of new rims for my 51 WD. I took the old wheels off with the tires and took them down to the co-op to have the put on the new rims. I took the wheels off by taking the two bolts to the eccentrics off. Anywho now I am putting the new wheels and tires on, what is the best way to go about doing this? I have bolted on the four eccentrics on one side but know I am thinking I cant get the wheel back on like that. Do I have to take the middle "rim" off and lay the wheel down and re-assemble everything like that? And when I get everything back on, should I be able to jack the wheel off the ground and loosen the eccentrics and move my wheel in and out?
Thanks
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 7:26pm
loosen the cam bolts, put wheel clamps on one at a time. Keep the outer bolts loose until all are in place. Tighten clamp bolts to the wheel center. Then tighten the cam bolts
phil
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 7:27pm
Anthony,
Probably several ways to do these.
I take the center wheel off the tractor. Stand the tire and rim up. bolt on one eccentric on to the wheel loose. stand the wheel with the eccentric onto the rail of the rim. bring the second eccentric on to the next rail and move it into position and place the bolt loosely into the eccentric. and then the other two the same way. Tape holds the key in place. Think I have some pictures:
Just how I do it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anthony Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 9:46pm
d17 brown do you do that while the wheel is attached to the tractor, or like sugarmaker is doing it?
When you get wheels and tires back on the tractor, can you spin the in and out with the wheel jacked up off the ground or do you have to put the tractor in gear and have the tire on the ground?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 9:58pm
 As long as the tire is off the ground and the brake is on or the tractor is in gear, YES!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2019 at 10:02pm
Thanks
No. With the tractor jacked up and supported properly, roll the tire and rim into place, then start bolting on the 4 eccentric assemblies leaving them unlocked and loos till all 4 are in place.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2019 at 2:04am
I always try to start with the rail with the "locks" on top (12 o'clock). Not only does it set the rim where I want it, but it stops it from moving on the rail. After that, I can slide the next two set two at 3 & 9, then finally, 6.
When I get them all set in place, I start at 12 and turn the eccentric 1/2 way, then I go across to 6, then 3 and 9. I keep turning them gradually until all are fully turned.
It's messy, but I use a lot of anti-seize on the eccentrics.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2019 at 2:14am
I believe you are supposed to tighten the bottom eccentric first the the two side ones and then the top.  At least that is how I was taught and I've never had a problem.  I use a very long breaker bar to tighten them with.
They are designed to use the power of the tractor to adjust them to where you want them.  Hence; Power Adjust.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2019 at 8:39am
Bottom first like John says.There's a reason.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2019 at 10:53am
My reasoning for doing the top first is that it lifts the rim into position. What is the reason for tightening the bottom first?
dallas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dallas Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2019 at 12:53pm
there is a difference  if the tractor is jacked up or not jacked up
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2019 at 1:56pm
dallas is right....when the tractor is not jacked up, you have the extra resistance of lifting the weight of the tractor. Getting that bottom one first limits the resistance to that only.
Then you will have only the normal resistance of tightening against the rim on the rest.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2019 at 2:01pm
I can understand that. I always try to get the eccentrics turned (at least) part way before I let the jack down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2019 at 7:51pm
According to the manual, and it doesn't specify jacked up or not, you tighten the bottom then 9 and 3 and then the top one.
I've always done it that way and I've never had any problems doing it.  I use a 25" breaker bar on a socket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2019 at 8:29pm
i do it on the tractor
phil
