Hydraulic gurus
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic gurus
    Posted: 27 Jan 2019 at 9:10pm
Just doing some daydream engineering, and have a question. Would there be a problem problem with 2 cylinders teed into the same valve with one pushing (extending) and one pulling (retracting) at the same time. Say for rotating a blade. I know there will be a different amount of fluid displacement.
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2019 at 10:18pm
Assuming they are both double-acting cylinders, and they have a similar setup for the opposote direction, there should be no problem at all.
The force developed would be the sum of the two forces developed by each. Since the one pulling has less area(because of the rod), its force is less.
I have seen some FWA steering setups this way.
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2019 at 10:45pm
Similar to the articulation joint in a 4wd tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2019 at 5:02am
Snow plows use the same set up...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2019 at 5:55am
DiyDave beat me...
old school snow plows for lefty-rightyCry
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2019 at 5:56am
It works, but try to bleed all the air from the crossover hose and that side of the cylinders.
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2019 at 6:37am
Thanks guys. I knew I was over thinking this. Crazy part is I was running our compactor at work, which has articulated steering, while I was pondering this.
This page was generated in 1.805 seconds.
