All Crop Combines - Cylinder RPM
snowman(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowman(MI) Quote  Post ReplyReply Direct Link To This Post Topic: All Crop Combines - Cylinder RPM
    Posted: 08 Jan 2019 at 3:04pm
Friend of mine is rebuilding the cylinder area of an All Crop 66.  Question came up that the book says that cylinder shouldn't exceed 1400 to 1600 rpm.  I know that is on the top end of things.  What are some typical rpm speeds that one might start out with for oats, wheat, clover seed and soybeans.  Just curious, my dad could remember that for clover seed that they would run the cylinder at a faster RPM.
Thanks,
snowman(MI)
1950 WD, 1966 D-10 III, 1961 D-10 II, 1966 D-15 II Gas, A-C Minibike, 917 Hydro Mower, 917 Hydro Blower w/cab, West Michigan "Allis Express"
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2019 at 7:15pm
I use my 72 mostly for soybeans and with cylinder bars still having rubber on the leading edge, I run the cylinder at about 800rpm. The bin sample would make a $500,000 combine jealous but I don't have a heated leather seat. Ryan
Walter(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walter(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2019 at 8:10pm
My 72 All Crop does an excellent job with half the cylinder bars removed.  I ran the combine with 4 cylinder bars.  The guy buying the grain at the elevator wished the operators of the expensive self propel combines would have the quality soybeans of  my AC .
wlambs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wlambs Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 9:01am
clover 1200-1600
oats /wheat 1400-1600
barley 1000-1600
soy 850-1400
if he needs screens i have a few.
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2019 at 7:26am
if soys are real dry ive had to run my cylinder down to 450-500 on my 90 to prevent splits
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2019 at 2:02pm
I came up with tachometer for All Crop combine at a sale but it didn't have mounting bracket or cable - does anyone have what I need to make it work (does it mount same on 66 and 72?). Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2019 at 7:16pm
Those tachometers are kinda rare. You would also need the special nut that replaces the standard one on the cylinder shaft. A person could easily make it I'm thinking. Ryan
Edited by Ryan Renko - 11 Jan 2019 at 7:17pm
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2019 at 7:57pm
The cylinder tach mounting on the clean grain elevator never made much sense to me, being as you adjust the speed from the left side of the machine. I've never used one, but seems you'd be walking back and forth a lot from the front of the machine, then back to the side. I've seen some literature showing the tach mounting right above the cylinder on the left side, which seems like it would be most ideal. Can anyone shed light on the subject?
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2019 at 8:16pm
Had one on my 72. Mounted where it was made for allowed me to see what my cylinder speed was from the tractor. Yes some walking to get the first set but then it would help me keep the throttle at the correct speed for the cylinder.
Den
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts.
