B trans flush
Grantjp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantjp Quote  Post ReplyReply Direct Link To This Post Topic: B trans flush
    Posted: 03 Jan 2019 at 6:08pm
So I drained the tranny/pto to replace the gear oil with universal tractor fluid. After discovering my hydraulics stopped working 2nd time I tried them.
From the fill plug oil looked clean but when I drained it, it was white milky soup.
I let it drain over night, now my plan is to flush with diesel, drain it and refill with the Walmart fluid.
Question
Should I engage the pto or hydraulic during diesel flush?
And
Should I drain and refill it again even after flush?
Thanks
Oh yeah one more thing
Is 303 tractor fluid tractor supply same as Walmart fluid?
Walmart $25 for 2 gal
Tractor supply $27 for 5 gal
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2019 at 6:28pm
Make sure you remove all 3 drain plugs.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2019 at 6:51pm
Ok...I've never been in a B/C transmission before, so I could be way off here, but isn't there a "cup" inside that catches oil to lubricate a countershaft? Seems I've heard this "cup" eventually fills with sludge/grime as well and can cause problems. I'm wondering if a diesel flush would do any good for that?
I've done a diesel flush on my Ford 8N, with really good results. I ran the PTO for a bit, and ran the 3pt up and down a couple times. I wouldn't want to run it that way for very long, but my thought process was that it should help some.
The flush helps if there's light sludge, but any heavy accumulations will need to be scraped out manually.
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2019 at 6:54pm
I'm not sure but I think that TSC 303 fluid doesn't say Allis 821 ? I do remember that I didn't buy it for my D 15 . Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantjp Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2019 at 7:01pm
All three are out
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantjp Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2019 at 7:25pm
Seems like I should use the pto and hydraulic a lil to get all the white film out.
Just didn’t know if the diesel would mess anything up?
Also wondering about getting all the diesel out?
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2019 at 9:00pm
Do you have cylinders in the system? they would have the dirty oil too
'41 Allis B
'45 Allis B
'49 Farmall Cub
'72 IH Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2019 at 9:21pm
Grant, the cheaper stuff from Tractor Supply is fine........ Many think that diesel is a contaminant, just like the water ( milky) in the gear lube... I would drain overnight and then put the Tractor Supply oil in the system.. Run it an hour or a week depending on how it works.  Run the cylinder in and out 20- 30 times.. It will still be milky, but should start operating better.. Sometime ( day or week) drain in out  again and refill a second time... After it warms up, you will still see some "milky".. but not much.. you will see that anytime you have .1% water or more in the system... a slight bit wont hurt you right now .... couple of changes should get you in decent shape.
Edited by steve(ill) - 03 Jan 2019 at 9:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantjp Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2019 at 10:34pm
I do have the small cylinder on the rear. It worked the week I bought it then last week it didn’t. Hopefully this fluid change does it.
Thanks for the info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantjp Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 1:40pm
Wouldn’t let me upload lil video
But the lift now works fine!!!
Thanks
Now I can move forward with 3 pt fab. And definitely a manual.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 4:10pm
I find it much easier to upload any video to my youtube account, then post a link here.
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 4:26pm
Great!
I changed the trans fluid in my B when I got a little over a year agi and once since then....but I haven't even tried the hydraulics yet.  My Dad had it for 25 years before that and never used them.  It's been a mowing machine only, but I would like to get a grader blade for it, so I guess it's time to try it.
Edited by HoughMade - 04 Jan 2019 at 4:27pm
1951 B
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 5:47pm
Is it possible the water in the fluid froze? That happened to my B.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 9:32pm
Grantjp,  Delighted to hear that my favorite is alive and well.  As we all know the hydraulics on the B are almost bulletproof.  Thinking back I really do not recall any problem we had with the hydraulics in a B.
Look forward to seeing pictures and hearing progress reports.
Take good care of my favorite
Good Luck!
Bill Long
