Auto Header Height Control Diagnostic |
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3662 |
Topic: Auto Header Height Control DiagnosticPosted: 09 Nov 2018 at 1:36pm |
We receive a lot of calls on Auto Header Height issues on F3 - R series using the 3 springs switch era . To the last caller/ hope this helps as a diagnostic guide. springs when header is up and bending them all at least 1/4" forward. When all the way down the springs would be bent at least 1/4" rearward by the brass rod. Make sure the rods and springs are not corroded and are capable of conducting current. Check for complete movement of sensor rod and fingers that rotate the control rod. These are the mechanical checks.
Connect test light ground to header and touch power to one of the individual springs. However remember IF the springs are all touching the brass bar on the plastic switch it will send power to all three springs ...Check for individual spring current while the switch is in the dead zone - neither front or rear brass bar touching any spring. Check at the 4 pin disconnect under the BLUE wire for RAISE. Remember red lower/ blue raise (the sky is blue it is up) only 2 power inlets - the later ones would only turn on from power from the orange wire from the header switch or the seat interlock module. 5. Unplug the harness going to the header - there will be a ground - check to see it is grounded it will be a black wire. With the engine running and the clutches on and the lower switch pressed - jump from the orange wire in the harness to the blue wire - the unit should raise. Then jump voltage to the two red wires - the unit will lower. IF the header still does not raise or lower the module is bad. * Make sure header raises and lowers in the off position on the AHHC switch. * NOTE header will not lower if the oil pressure switch is not providing continuity when engine is running. Check for oil pressure and defective switch. IF the header will raise very slowly the problem is in the header valve and the 71321101 o ring has deteriorated and allowed poppet to move with the seat. This requires removing the valve and overhauling with new o rings and loctite the seat in place.
IF THE UNIT HAS A SEAT INTERLOCK (later R50 series and up) make sure the seat switch is connected and closed. If still it will not work -this is for the auto header control- connect the module power orange wire to the orange and white header clutch wire and this will power the switch - three position and on some back feed the AHHC module. in mind if the seat module is totally bad - it will not let the un loader function. if the un loader will not work - it will have to have a relay installed with an on off switch. or just replace the $eat module 71358611 R50 71363940 R52/62 etc, Bypassing the seat interlock can cause a serious safety issue.
Edited by tbran - 09 Nov 2018 at 1:54pm |
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 09 Nov 2018 at 1:44pm |
We receive a lot of calls on Auto Header Height issues on F3 - R series using the 3 springs switch era . To the last caller/ hope this helps as a diagnostic guide. 1. Make sure brass rod on header switch is touching all 3 springs when header is up and bending them all at least 1/4" forward. When all the way down the springs would be bent at least 1/4" rearward by the brass rod. Make sure the rods and springs are not corroded and are capable of conducting current. Check for complete movement of sensor rod and fingers that rotate the control rod. These are the mechanical checks. 2. Check for blown fuse on AHHC. Check for Voltage at the three springs on header rocker switch. Key on, engine NOT running, AHH switch on MED , both clutches ON, click the down button on header height . Connect test light ground to header and touch probe to middle spring. IF no current go to connector plug in for header. IF no current go to switch in cab and check for power to three position switch from orange wire. Correct any problems to get current to three springs. Three positions on the rotary dial sends power to one of the individual springs. However remember IF the springs are all touching the brass bar on the plastic switch it will send power to all three springs ...Check for individual spring current while the switch is in the dead zone - neither front or rear brass bar touching any spring. 3. Current should now be present at the plug in for the header. The red wire has to have voltage to LOWER the header; there must be a jumper on the combine header harness to make BOTH header harness red wires receive voltage - one red wire hot will not lower the header. Check at the 4 pin disconnect under console for voltage on the red wires for lower and rotate the switch down on the header to raise position to get current on the BLUE wire for RAISE. Remember red lower/ blue raise (the sky is blue it is up) 4. Finally if no auto height action is occurring, check the Red or red/yellow and in some models ORANGE wire for power to the MODULE itself. The early series had only 2 power inlets - the later ones would only turn on from power from the orange wire from the header switch or the seat interlock module. 5. Unplug the harness going to the header - there will be a ground - check to see it is grounded it will be a black wire. With the engine running and the clutches on and the lower switch pressed - jump from the orange wire in the harness to the blue wire - the unit should raise. Then jump voltage to the two red wires - the unit will lower. IF the header still does not raise or lower the module is bad. * Make sure header raises and lowers in the off position on the AHHC switch. * NOTE header will not lower if the oil pressure switch is not providing continuity when engine is running. Check for oil pressure and defective switch. IF the header will raise very slowly the problem is in the header valve and the 71321101 o ring has deteriorated and allowed poppet to move with the seat. This requires removing the valve and overhauling with new o rings and loctite the seat in place. IF THE UNIT HAS A SEAT INTERLOCK (later R50 series and up) make sure the seat switch is connected and closed. If still it will not work -this is for the auto header control- connect the module power orange wire to the orange and white header clutch wire and this will power the switch - three position and on some back feed the AHHC module. in mind if the seat module is totally bad - it will not let the un loader function. if the un loader will not work - it will have to have a relay installed with an on off switch. or just replace the $eat module 71358611 R50 71363940 R52/62 etc, Bypassing the seat interlock can cause a serious safety issue. Edited by CAL(KS) - 09 Nov 2018 at 1:47pm |
Dad- WD, D17D, D19D, RT100A, 7020, 7080,7580, 2-8550's, 2-S77, HD15 |
tbran
Posted: 09 Nov 2018 at 1:55pm |
Sorry guys for the choppy post of many colors - not very tech savvy on cleaning it up.
DrAllis
Posted: 09 Nov 2018 at 2:10pm |
Great info !! Another thing I have seen too often over the years...…...the six pin plug from the header to the throat is plugged in upside down !!! Now, if the plastic plugs are in good condition (which they aren't any more) you can't do this, but like I say they will connect bass-ackwards when the plastic is all deteriorated.
tbran
Posted: 09 Nov 2018 at 3:50pm |
The most common issue we run into is the wires BREAK INSIDE THE HARNESS right where the throat bends the harness as it raises and lowers. One can remove the outer coating and start pulling on the wires - they will pull in two...breaking the coating.
We still see the unsealed module units pop up from time to time - these were a safety issue and were recalled..
tbran
Posted: 09 Nov 2018 at 3:54pm |
Yes Doc, hard to fix stupi....anyway.. the pn for the plastic cover for the plug in that comes apart is 71340683 - the white part deteriorates normally - if someone plugs in backwards it happens sooner.
automaticdave
Joined: 20 Jan 2011 Location: Granton, ON Points: 261 |
Posted: 09 Nov 2018 at 5:17pm |
Thanks to you guys that contibute to putting this post together. This is very valuable information as well a great diagnostic procedure, I will print this off and stick in our R-50 service manual. Thanks again Dave
Dave974
Joined: 18 Aug 2017 Location: Fort Wayne, IN Points: 77 |
Posted: 12 Nov 2018 at 1:26pm |
I also wanted to say thanks for compiling and sharing this information. The AHHC on our F3 has been acting up in recent years and this will be a great tool to use for figuring things out.
Thanks again! Dave
