Biodiesel and Ethanol |
Page 12> |
Coke
Topic: Biodiesel and EthanolPosted: 11 Oct 2018 at 8:54pm |
Dunno if this belongs here, or if there is a 'General' area.
Does biodiesel have the same storage issues as ethanol does? Stations round here sell biodiesel blend up to 20% and I'll bet some don't even label it. Found this document but not sure what it's saying, if I'm B5 it might be OK, B20 is more hit or miss. https://www.sciencedirect.com/science/article/pii/S0378382014003361 |
1957 D17 Diesel w/ M&W Pistons
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55294 |
Posted: 11 Oct 2018 at 9:12pm |
I wouldn't use anything, but real diesel, that bio stuff has algae problems, particularly in plastic tanks. Who needs more headaches...
Coke
Posted: 11 Oct 2018 at 9:49pm |
What I'm saying is round here, in the corn belt, who knows whats going on. All gas has up to 10% ethanol, we only get one diesel nozzle y'know? Some have the biodiesel blend stickers on, some don't, but I wouldn't take it as a guarantee.
I don't store it anywhere but the tanks of the vehicles, but the D17 isn't going to see massive amounts of use, so I'm a bit worried about it sitting. Don't get me wrong, I love biodiesel and ethanol, just worrying about it's stability issues. |
DougS
Posted: 11 Oct 2018 at 10:06pm |
My BMW specified no more than 5% bio diesel. I think BMW was more concerned about quality than anything. I remember pulling into a Kum & Go and finding their pump labeled "may contain up to 20% bio diesel." I got back into my car and drove to the next station. At work I had a remote radio site that ran on solar with a diesel backup. It was really a generator with a solar assist. One year of bio diesel and the algae headaches caused me to become very particular about the fuel. This was stored in a steel tank, no less.
shameless dude
Posted: 12 Oct 2018 at 12:54am |
our stations all say "no bio diesel here", so they musta got the hint?
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 12 Oct 2018 at 6:07am |
In the summer months Minnesota requires all diesel fuel to be 20% bio. Now I order my fuel after October 1 and before May 1 so I can get the 5% bio diesel. But you have to check because many will still sell a blend of more than 5% in the winter and more than 20% in summer. Filled up my semi truck last winter and as soon as it got around zero it gelled up even though I had treated it. That was fun. My old supplier sometimes sold 40% and it ruined two injector pumps for me. Since Minnesota mandated biodiesel all my steel diesel tanks on my equipment have rust in them to some degree. Something that I never saw before biodiesel. I'd prefer 0% bio but in Minnesota, the communist state that it is, pure diesel fuel is against the law.
Edited by Lonn - 12 Oct 2018 at 6:09am |
Wink I am a Russian Bot |
modirt
Joined: 18 Jul 2018 Location: Missouri Points: 9456 |
Posted: 12 Oct 2018 at 6:34am |
Interesting to see the comments from BioD users. I was not aware of the storage or user problems with BioD. The problems with ethanol are well known. What I have always found more interesting is how the two of them are made. Ethanol is made in plants via the fermentation of corn.....essentially large moonshine stills. Same exact process. The only thing they do different is to contaminate it with regular gasoline when it leaves the plant, so as to prevent somebody from hijacking a tanker truck and selling it as moonshine. Ethanol plants are regulated by ATF. BTU value of ethanol is about 70% or so of regular gasoline. So as a fuel to put in a standard gasoline engine it kinda sucks, and that is before the problems with water and corrosion start showing up. Worse, when they first started, they used more BTW's of energy to make the stuff than they got out of it in ethanol. Would have made more sense to burn the propane and/or natural gas it took to make the stuff instead. But it does take a lot of corn out of storage. Corn price (value of ethanol) now being tied pretty close to the btu value of unleaded gasoline at the pump. BioD on the other hand, is a straight forward chemical process. Made by mixing some type of oil (from vegetable oil or animal fat) with lye and methanol. No heat or other processes other than separation and cleanup needed. You can actually make BioD in your kitchen in a two liter soda bottle. Takes just a few seconds to see the process unfold. Outcome is 90% BioD and 10% glycerin. BTU value of BioD being closer to 90% that of regular #2 diesel and has the same lubricating properties as diesel with sulfur. It is also a solvent, so using it tends to cleanup the fuel systems. Back when it first started, there were a lot of complaints about how it gunked things up. It will also gel at a higher temp than diesel, which screws things up in cold weather. Most diesel engines will run on 100% BioD with no modifications. Not so with E80 or higher. What has also hampered BioD is there is no vast surplus of oil crops (like soybeans) like there is for corn. Most of it was already spoken for in the food industry. McDonalds doesn't care what oil for their french fries costs. You can't pay more soy oil than it's BTU value at the pump is worth, or you will go broke. A lot of the early BioD plants ignored this and went bankrupt as a result. So BioD always seemed to me to be the better of the two. But both have their flaws in comparison to the oil based fuels. But if you ever run out of the oil based fuels, which mankind will at some point, at least you have an option for a renewable liquid fuel you can dump in the tank so you don't have to go back to farming with horses. |
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12422 |
Posted: 12 Oct 2018 at 6:40am |
I've been of the opinion for some time that the issues with biodiesel can be solved with some good research and some smart chemists and chemical engineers working on it. Maybe not, but I think so. When economics demand it (if?), that work will begin more in earnest.
only AC orange
Joined: 06 Dec 2014 Location: Eastern Indiana Points: 609 |
Posted: 12 Oct 2018 at 6:42am |
I have been through Fuel algae problems and they weren't fun! When my D-21 was overhauled 6-7 years ago, it had mostly sat previously and not used (yes, I had used biodiesel). After overhauling, wanted to get some hours on it by plowing/chiseling - fuel gelled, stop flowing and was it a mess! Ended up draining fuel system, flushing out, putting in fresh pure diesel, and a coil of number 2 copper in fuel tank - copper is an enemy of algae - copper sulfate used to treat algae in ponds/lakes. NO problems since!
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8984 |
Posted: 12 Oct 2018 at 7:58am |
With daily use,biodiesel isn't a problem....it's the setting that makes the ugly show up. So far,I can still get straight diesel off the tank truck.Still have rusty fuel tanks from one winter of bio....
Edited by SteveM C/IL - 12 Oct 2018 at 7:59am |
DougS
Posted: 12 Oct 2018 at 8:01am |
BioD has 90% the BTU of petro diesel. It's not a huge difference, but you are losing a few HP when you use it. This transforms into a few less MPG. The same goes for E10. It has about 3.5% less BTU than gasoline. There are those who say that E10 burns cleaner than gasoline when the engine needs a tune up. I'm not one who skips tune ups, so that argument falls on my deaf ears.
They label E10 as "Super" here in Iowa. This harks back to the day when they blended ethanol with 87 octane gasoline and ended up with an 89 octane fuel. Now they blend the ethanol with 84 octane gasoline with a resulting octane rating of 87. There's nothing Super about it anymore. Edited by DougS - 12 Oct 2018 at 8:08am |
Clay
Joined: 11 Sep 2009 Location: Udall, Kansas Points: 10413 |
Posted: 12 Oct 2018 at 8:58am |
I avoid ethanol when ever possible. It is too hard on fuel system components. My chainsaw will not start on ethanol. Pure gasoline or 100LL works great in my chainsaw. Even my saw dealer told me to not use ethanol gasoline.
There are STC's (Standard Type Certificate) available for many piston aircraft. No ethanol is allowed. The ROTAX 912 engine in a Flight Design CTSW requires premium unleaded no ethanol gasoline. I can tell a difference in my D-17 when 10% ethanol is used. Actually burns more gallons per hour than pure gasoline. Ethanol may help the grain industry but it does nothing to help our engines. As for bio-diesel......keep it. Not for my engines. I work too hard to make a living and can not afford to put crap in my fuel tanks. |
Lonn
Posted: 12 Oct 2018 at 11:54am |
And then I'll here some liberal...... farmer mind you, that complains that farming has turned into a corn and soybean industry only. Two crops only. More disease, eggs in one basket thing. I agree but then they are 100% for more ethanol and bio diesel subsidies and/or mandates. It just doesn't make sense.
jiminnd
Joined: 16 Sep 2009 Location: Rutland ND Points: 2337 |
Posted: 12 Oct 2018 at 5:41pm |
Not going to get into any arguments, just my experience, have used 5% bio and 10% ethanal for 20 plus years, absolutely no trouble. Just my experience.
DougS
Posted: 12 Oct 2018 at 5:52pm |
That works if you buy it and use it right away, jim. I wouldn't recommend buying it and storing it for a couple of months or more. I use E10 in my car. I pay up the nose for regular or premium without ethanol if I'm putting it in a container and using it over the summer or winter for my lawn mower or snow blower. I've changed too many previously white, now black and clogged, filters on my gensets that had a tank with a six month supply store of 5% diesel.
DaveKamp
Posted: 12 Oct 2018 at 10:09pm |
This is incorrect. One gallon of 89 (RON) unleaded gasoline yields 124,000btu. One gallon of ethanol yields 76,000btu. 76,000 / 124,000 = 61.29%. A little more than half the fuel energy. The biggest issues with ethanol include: 1) It's polar, and caustic... ph 7.33, so it's a base. It etches away the tank, fuel lines, and pot-metal castings of fuel system components... and includes it in heavier gasoline fractions and water as black goo. 2) it is extremely hygroscopic... it acts as a dessicant- will withdraw moisture from the air, even when in suspension with gasoline. 3) It's a carbohydrate, which means it will not dissolve into, or be dissolved by... a hydrocarbon. It can only be in suspension, and if allowed to settle, it will stratify in layers with water precipitated to the bottom of the tank, followed by supersaturated ethanol, then gasoline's heaviest fractions, with the lighter ones allowed to evaporate off. Evenutally, it turns to a nasty, black goo noted above. The performance issue with ethanol blends, is that the flame speed of carbohydrate fuels, and the expansion curve pressures are totally different from gasoline. Using a mixture of ethanol and gasoline in an internal combustion engine, is exactly the same as using a combination of wood-chips and black powder in a high-power rifle cartridge, or the converse... using a mixture of modern smokeless rifle powder and corn starch in a damascus shotgun barrel... or worse yet, trying to run a steam engine on dry pine slabs, or wet oak logs- one cannot optimize for two different burn cycle constants at the same time, and ANY repeating burn cycle is substantially complicated by the inclusion of water. If you build a fuel system from the git-go to utilize Ethanol, it's possible to get a really great result. Same goes for methanol... my Grandfather distilled woodchips to make solvents AND fuel his Waterloo Boy sawmill engine during the fuel rationing of WW2... and it did just fine... but he didn't mix gasoline with it, and sure as heck didn't drink it... Biodiesel's challenge, is that the bio part is naturally very uncontrolled at times... and it's character is very subject to seasonal challenges. I've had plenty of friends with good experiences with bio in trucks they run on bio they produce on their own... they make their own production systems, and fit up their trucks and Jeeps, running on old-time mechanical injection turbodiesels... and they do just fine (aside from government regulations having a fit over not paying road-fuel taxes, right?). I've got a buddy who uses home-brew bio in a Lister, and it generates power and heat for his hunting cabin just fine. I've run bio grades in my company service truck, and had many instances where it was just fine, but I've had plenty of instances that gelled up lines, plugged up filters and ruined injection pumps... so we don't run diesel service trucks anymore. From an engineering standpoint, it's best to build it to run on one, or the other, and from that, you can have a great system. Don't mix 'em, it just makes a terrible pile of variables with which to contend. |
DrAllis
Posted: 13 Oct 2018 at 6:43am |
Since the early 1980's until now, I have had six F-150 pickups. They all have used 10% Ethanol exclusively. I just added up the odometers and I am at 990,000 trouble-free miles on all of them. I also have used 10% in all my GM, Chrysler and Ford cars/vans...again zero problems. I never use it in my lawn mowers. I don't have a chain saw.
DougS
Posted: 13 Oct 2018 at 6:57am |
EPA tests have proven that you get about 4% less MPG with E10. Your pump price should reflect this. $3.00 regular gasoline should mean that E10 would be priced at $2.88. Unless your state gives a motor tax break on E10, you are quietly paying a little more in road tax. Here in Iowa regular is priced at 30 cents above E10, across the board and everywhere. I wasn't a resident here when all that went into effect, but I suspect that regular gasoline is being taxed at a much higher rate. Regular gasoline here is priced well above the national average. E10 is priced near the national average.
Dave H
Joined: 11 Sep 2009 Location: Central IL Points: 3610 |
Posted: 13 Oct 2018 at 8:04am |
My two chin saws do not know what pure gasoline is. They always run great. The E 10 sits in the lawn mower and lawn tractor tanks all winter with additive. twenty some years with the tractor and 19 with the Z turn. nary a problem with the gas. I am not proponent of E 10, but normally don't blame all my problems on E 10.
Edited by Dave H - 14 Oct 2018 at 8:38am |
chaskaduo
Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Posted: 13 Oct 2018 at 8:57am |
Got to love politicians and their rose colored vegetable powered world glasses. Just remember, You will do it and You will like it, we have ways of making You like it, now do it.
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3671 |
Posted: 13 Oct 2018 at 9:34am |
Bio fuels need to be used, not stored. For winter fuel storage in equipment, I've found that filling equipment tanks with best quality fuels along with a good fuel additive works best. I repeat, that is best - not perfect. Locally our Shell stations usually have best gasoline & diesel. I say that cause both our gas & diesel vehicles usually get better mpg with Shell products, no matter the time of year.
Outside of Illinois, My diesel pickup's better mpg results were from fuel purchased from FleetFarm in Owatonna, MN & some BP stations in other states. Most Shell stations are good. Some here & there are not so good. Just got to keep track. You never forget where you purchased chitty fuel. |
DaveKamp
Posted: 14 Oct 2018 at 8:31am |
This advice is paramount... When ANY blend exists, this is when all bad things have time to happen. Keep it fresh and moving, and one will have the least issues. ![]() |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35692 |
Posted: 14 Oct 2018 at 8:41am |
IF your equipment has commercially made plastic fuel lines or components INSIDE the fuel system DO NOT USE BIO fuel, will disintegrate from the basic(pH) nature of the Bio mess. My Ford 7.3 owners manual states that FLAT OUT much as many of the GM Duramax manuals, fuel lines, fuel transfer pump casings and parts, even the Tanks are susceptible to damage. Late model tractors of all variety have plastic fuel lines and tanks/support items as filter housings. Buddy of mine USED to make his own bio, ruined his truck parts, his Bobcat and One older but recent build Deere fuel systems where had to replace all the plastic parts $$$$$. Was almost pure Bio but even in small amounts of blend has a same reaction just takes longer.
Edited by DMiller - 14 Oct 2018 at 8:42am |
Coke
Posted: 14 Oct 2018 at 6:59pm |
So what's this low sulfur stuff about? What's the sulfur for?
I been looking at all my local diesel places, they all seem to be doing Bio. Not a Shell near me that sells diesel. |
Clay
Posted: 14 Oct 2018 at 8:33pm |
Unfortunately, sulfur has been mostly removed from diesel fuel. The sulfur acted as a lubricant in the injector pump.
A side benefit of the sulfur was as a micro nutrient to the soil. Sulfur has also been scrubbed from coal fired plants. Sulfur, in large enough quantities, can cause acid rain. This is bad for marble. We now have to add sulfur to our fields. |
DougS
Posted: 15 Oct 2018 at 4:26am |
I *think* the railroads still use diesel with sulfur. Don't quote me until you've looked it up. In any event, I doubt you'll be able to purchase any fuel from them. Modern diesels with pollution equipment hanging on them require Ultra Low Sulfur fuel. "They" say you should add a lubricant to your fuel if you are running older equipment that was designed for older diesel fuel. I've looked up some diesel fuels and some claim to have added a lubricant of their own, depending on location. This makes me wonder if some oil companies even sell their own brand of diesel fuel or if they just market some generic stuff. |
HoughMade
Joined: 22 Sep 2017 Location: Valparaiso, IN Points: 714 |
Posted: 15 Oct 2018 at 9:21am |
Same here. There is no "pure gas" or "no-ethanol" option where I live and has not been in the 20+ years I have lived here. I've wore the crankshaft out on a push mower after 16 years- original carb still worked. I've got a John Deere 325 lawn tractor that's been mowing grass since 1997. No fuel-related issues. I've got a Troy-Bilt Horse tiller with a Tecumseh HH60 built in 1976. No problems. 15 year old chain saw- no issues. In my AC-B, I use standard 87 octane with an ethanol treatment. So far, so good. However, I buy the gas and use the gas. No gas sits more than a month. At the end of the season, everything gets run dry. I understand that this is easier in a homeowner situation as I'm not buying in bulk, but my entire experience with E-10 is that when bought and used, it causes no issues. Sitting around? Oh yeah, problems. At the beginning of this summer, I tore into an old Wards tractor as a project for my son. It had been in a barn for over 10 years. The fuel bowl was the worse I had ever seen. The brass float had pinhole leaks all around it at the exact level where the fuel sat for so long....and the smell....
Edited by HoughMade - 15 Oct 2018 at 9:24am |
1951 B
DougS
Posted: 15 Oct 2018 at 10:21am |
Unusual that you can use 87 octane in your chain saw. I have three two cycle pieces of equipment and the manufacturers both recommend premium fuel. As little fuel as they use, I just fill my mix can with premium.
HoughMade
Posted: 15 Oct 2018 at 10:53am |
I mix it out of my larger fuel cans which all have 87. No problems. All of our gas here has ethanol, not just 87. We are in one of 2 counties in Indiana subject to the EPA's Reformulated Gasoline Program meaning that our gas is "special" gas. In addition to other requirements, it has to be "oxygenated" which around here is normally accomplished with ethanol.
1951 B
Coke
Posted: 15 Oct 2018 at 1:43pm |
Is that just Indiana? I've seen a lot of pumps round here that say all gas may contain up to 10% ethanol, and that's all the selections, not just the 87.
As to the biodiesel, I know for sure a bunch of places round here get their diesel from a different place than they get their gas, some even have stickers to that effect. |
Page 12> |
