Snap coupler dimension variations |
Post Reply ![]() |
59f100292 ![]() Bronze Level ![]() Joined: 11 Dec 2011 Points: 63 |
![]() ![]() ![]() ![]() ![]() Posted: 26 Sep 2018 at 2:17pm |
I have read there are variations in both lift arm width, and tongue length dimensions through the spectrum of CA to D series snap couplers. Would a post hole digger off a D-17 fit on a WD?
brkfldj ![]() Bronze Level ![]() ![]() Joined: 13 May 2010 Location: Sharpsburg, MD Points: 168 |
I don't know the answer, but I bet you could pm IBWD MIke and learn a quick answer. He had a post on 6/11/18 that causes me to think he will have many answers about snap coupler interchangability.
Jim |
JC-WI ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: wisconsin Points: 34306 |
yes
The truth is the truth, sugar coated or not. Trawler II says, "Remember that." |
wfmurray ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Bostic NC Points: 1225 |
We put a rippper for a C A on D 14.Had to add 10 inches to beam and rework lift arms . Worked out good.
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10757 |
Depends on the model. The #10 you will need a different bracket that bolts to drawbar bracket. HTH Tracy
On a related note, I’ve got a 6ft rear blade that doesn’t fit the WD, as the lift arms are about 3” too narrow for the tractor’s lift arms (27.5” on the blade, 30.5” on the tractor). Is it safe to assume the blade was made for a CA snap coupler? Would it fit anything else? D-10/12? Not sure yet if I will try to modify it to make it work or sell/trade it. Want to advertise it correctly if I’m going to sell it.
Post Reply ![]() |
