7000 series Pre-cut floor mat: who's is best?
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Topic: 7000 series Pre-cut floor mat: who's is best?
    Posted: 08 Sep 2018 at 2:00am
Hey all,
Just as the title says, trying to find the best quality floor mat I can for the 7040.
Thanks!
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2018 at 8:02am
I got one from Shoup...if ya have a PD, and maroon belly, you'll hafta cut the holes for them...
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2018 at 8:39am
who has them for open station maroon chassis PD tractors?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2018 at 9:49am
Check with Fehr cab interiors.  I just got a cab kit for my 6080 and it looks amazing.  They do floor mats as well.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2018 at 6:00pm
 Got a floor mat from through All State Ag Parts. Very happy with the fit but as stated above, will have to cut holes for power direct. They called it a jute backing but really just thick rubber molded to the mat.
DaveWisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2018 at 7:13pm
How about a D21
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2018 at 3:44pm
Good question, I would like to know that as well, as I have a 7030 that will likely return to factory open station status at some point. That point will likely be when I get a shed to put it in, although its an early unit with the open station only linkage rather than cable controls so a little weather probably wouldnt hurt it.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2018 at 8:44pm
Originally posted by DaveWisc. DaveWisc. wrote:
How about a D21
D21 to my knowledge never had a floor mat from the factory, so unlikely anyone is reproducing what never existed.  The D21 was pretty much always an open station tractor from Allis, all cabs that I know of where aftermarket.
Still in use:
acnh210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acnh210 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2018 at 9:41pm
I recommend the Hycapacity brand. Its a thick foam. power director holes are 1/2 cut out. Just finish punching them out. I put one in eleven years ago. It still looks new, minus the grit and grime.
Terra Tiger, WD, 7040ps, 8050 with westendorf loader, 8050ps fwa.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2018 at 9:20am
I've used Fehr for several gleaner cab kits & like them. Their floor mats were 1/2" thick dense foam fused/glued to a 1/8" durable rubber matting. Good folks to work with in Fairbury, IL.
Here's their weblink
http://www.fehrcab.com
This page was generated in 0.287 seconds.
